I updated ESPHome to the new version (2021.12.1). But now I am unable to see the logs of my devices. They still work fine, but I would like to be able to run OTA or logging in the future.
All my devices are build with firmware 1.20.4. When I open the log I get an black screen, see screenshot. I can only access these devices wireless, so i am not able to test if the log still works via usb.
I am afraid am I not. I just did the add-on and I did not update my devices, they are still on 1.20.4. But somehow with ESPHome back on 1.20.4 I still cannot access them. What is the process?
First try a different browser/machine and clear your cache on the machine you used when you got the error. Make sure it’s not just in the browser now.
Technically you should just be able to remove and reinstall and everything should restore itself. Besides the HA backup, I like to backup the esphome folder. It contains all your node .yaml files. In the config folder you will see the esphome folder.
I’d restart the supervisor in between remove and reinstall. Because it saves its settings that may not work. If it doesn’t, follow the above but rename the esphome folder to esphome.old.
Then inside /config/.storage you will see esphome text files. Cut and paste any esphome files into the esphome.old folder. Then remove and reinstall. If all goes well you can safely delete esphome.old
Hi Mikefila, thanks. But no luck, I have re-installed ESPHome and are now on version 12.1. Logs on nodes are still black and suddenly several notes are offline now… Should I just wait for an updated ESPHome version?
Did something happen to your back-up of 1.20.4 that you reinstalled the newer version? The reason to remove everything was to ensure that no files were left behind from 12.1.
There is also about 6 months difference between the your node firmware and 12.1. I’m wondering if the log output is related to the nodes not being updated. Do you have a spare esp that you could test flash with updated firmware and see if the log output is visible?
I was able to use Edge browser to run logs and updates … then went back to Chrome. There is a delay of several minutes before logs or updates show anything in the screen in Chrome. I did this without regressing from HA 2021.12.7
