New fork of pollenprognos-card
Fellow Swedes and more specifically, you who suffer from the yearly ailment of pollen allergies and thus might also be using JohNan’s excellent pollenprognos-integration,
I’ve made a fork of the fork of isabellaalstrom’s pollenprognos-card.
TL;DR: you can find it here: GitHub - krissen/pollenprognos-card: A custom Lovelace card to display pollen information
There was a glitch which I hope is fixed. Added ability to choose the number of days (0-4) to be shown in the normal layout; like so:
Two days without text:
Four days with text:
It is also possible to choose 0 days. However, in that case, might I suggest you try the minimal layout instead?
Minimal, without text and title:
Minimal, with text and title:
@krissen Nice work.
It looks nice but there is a couple of glitches.
First it doesn’t seem to handle the value -1 which is “Ingen information”.
The second is that it hides all allergens with the value 0, Inga pollen. It should be selectable in the configuration.
The values for “Onsdag” is -1…
Rudimentary fix implemented in the latest release. Hope it works for you; it did in my own testing. “-1” is really a NA value, I think. The latest release filters these to “0”. A proper way would be to add text and image for NA. Feel free open an issue to remind me. Also, PR:s are welcomed!
Rudimentary support has been added, use variable pollen_threshold. Default value is 1, for the same behaviour as before. Set to 0 to show all, or any other number to filter. Currently, it checks if there is higher value than pollen_threshold in any coming days (1-4), regardless of days_to_show variable. Better support would be if it would only check days_to_show. Feel free open an issue to remind me. Also, PR:s are welcomed!
Better support for -1 has been added in the most recent release (v1.0.3). It now tells you there is no information rather than fooling you into believing that there wouldn’t be any.
Also considered implementing a threshold according to days to show, but I kind of prefer it as it is. Just let me know if anyone would prefer it otherwise.
Great card! Thanks a bunch! How would I go about changing the font-weight of the header “Idag”, “Imorgon”, “Övermorgon”? I’m using card mod, and can’t seem to find the element to style. Kind regards.
Installed it in HACS but cant find the card in Lovelace.
The card does not list under my card
Any idea whats wrong?
Jag har samma problem. Hittar inget kort.
Same here. No card is showing when I try to add it
Apologies for the late reply @jacobloris @nikee. Also ping @vondewall.
  1. Have you added the resource? See this thread.
  2. Currently, you need to add the card manually. See ludeeus’ explanation for how, here. In short, if you add the card in the UI editor, having pressed add; scroll down. Choose “manual”. Paste in this code:
type: custom:pollenprognos-card
city: Forshaga
show_text: false
days_to_show: 2
allergens:
  - Al
  - Alm
  - Ambrosia
  - Björk
  - Ek
  - Gråbo
  - Gräs
  - Hassel
  - Sälg / vide
Should look like this:
Thanks, now it works. Great card. Very useful!
:pray: Happy to hear it worked!
I am having problems using this card. I installed in through HACS, but it didn’t work as a custom integration, but Lovelace.
When trying to use the card with the code I am getting this error message as seen in the screenshot.
ha1
Any idea of what I’m doing wrong?
Hi Jonas,
JohNan’s Home Assistant Pollenprognos integration is a prerequisite; that is the custom integration that provides the data shown by pollenprognos-card. Have you installed it?
Kind regards,
Kristian
Hi Krissen,
Do you know where to find the Url… to activate my pollen integration… need to see what causes the problem for my family
Sent a PM.
Hi!
Yeah, I’ve done that and found the API-URL too.
I can see the two sensors of Gräs and Björk, and they work. But I can’t copy/paste the code to get the code above to work.
Appriciate you trying to help me out.
Hmm. Sensors are there; great. Do you still encounter the same error as in the screenshot you embedded in your post above? That would suggest that the following will not help, but nevertheless want to check:
Have you added the lovelace resource; see this post, above?
I believe I have.
Adding two more pictures.
Is there anything I could double check manually in a config file?
Here are the two sensors above, and the card underneath is with the code copy/pasted in a manual card/code.
Really not sure what is going on, so the following is just grasping for straws. In order, try:
  1. In your image, you correctly show pollen-sensors. Great. But are they also of the same city? Is your pollenprognos integration set up for the same city that you try to render the lovelace card of, that is: Forshaga?
If you open up your sensor for, say, Björk. Is the entity id indeed sensor.pollen_forshaga_bjork or is it something else? If it is something else, we might have found the culprit, as the error message you’re seeing would correspond with the entity it is looking for isn’t there. (For the two sensors you’ve configured in the lovelace UI editor, it would be looking for sensor.pollen_forshaga_bjork and sensor.pollen_forshaga_gras.)
One way of checking this, is opening up the Pollenprognos -integration, and viewing the list of it’s entities.
  1. It looks like you have several lovelace pollenprognos cards installed (specifically pollen-card and pollenprognos-card). They shouldn’t clash, but :man_shrugging:. Try removing pollen-card?
  2. Could you send a screenshot not only of the rendered error message, but also how the code looks before you save the card configuration in lovelace? Just to be sure.
