My scripting skills have hit a wall in Home Assistant automation
I want to create entities dynamically With out knowing the “static” entity name at home assistant.
I need to create an integration but my python skills are limited. I think i found a workaround but the following would be great.
Create a general rest api integration where you can hook up a hostname and token. and based on the rest properties (multiple) entities are managed.
you can do a lot with the config but I want to bring my network management to home asssistant where i can manage what device uses what kind of internet connection. (direct,pihole,vpn.no internet)
and a white list of ip’s able to connect to my local network.
Oh sorry I thought i still had it in edit when i went to bed.
I have a system that sends. Ips and the state to HA with rest calls.
those are read only so the best solution to create select entities that can be selected into a new state is unusable.
Only way to create dynamically editable entities from home assistant is by writing a integration.
I am a linux power user but not a programmer. can do very neat things. improvements at my asterisk phone home assistant end point. - YouTube
But programming a integration is not something i can do easily.
I don’t know what kind of level of python developer you need to be to create an integration but i’m not it.
creating a general integration that connects to a rest server that has one endpoint with all the information to create the entities. (and perhaps something smart to get updates of one entity)
Will cover this gap in home assistant.
You might want to rephrase you FR to something like:
“Ability to create working helpers via the REST api”
and include the log message:
2023-08-06 10:51:07.255 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities input_select.test_new_1 are missing or not currently available
