Hi All,
New to all Home assistant and just installed Hass io on a Raspberry Pi 3 B+, I have coding skills what so every and at the moment I am just scratching around trying to get things working by checking out the help on these forums and uTube videos, and here is the BUT! I just can’t seem to get my head round some thing.
What I am trying to do is add a Broadlink controller, I have cut and past some code into the Configuration.Yaml via " Configurator " and get the green tick but when I check my config I get the following error. The videos make it look so simple The Broadlink bit is at the bottom
Sorry if this post is a mess couldn’t seem to find the option to view before posting and wasn’t sure about the code
__________________________________________________________________________
Preformatted text`Invalid config for [cloud]: [-platform] is an invalid option for [cloud]. Check: cloud->cloud->-platform. (See /config/configuration.yaml, line 68). Please check the docs at Home Assistant Cloud - Home Assistant
Component not found: switches
indent preformatted text by 4 spaces
> homeassistant:
# Name of the location where Home Assistant is running name: Home # Location required to calculate the time the sun rises and sets latitude: 52.9295 longitude: -1.4342 # Impacts weather/sunrise data (altitude above sea level in meters) elevation: 0 # metric for Metric, imperial for Imperial unit_system: metric # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones time_zone: Europe/London # Customization file customize: !include customize.yaml # Show links to resources in log and frontend introduction: # Enables the frontend frontend: # Enables configuration UI config: # Uncomment this if you are using SSL/TLS, running in Docker container, etc. # http: # base_url: example.duckdns.org:8123 # Checks for available updates # Note: This component will send some information about your system to # the developers to assist with development of Home Assistant. # For more information, please see: # https://home-assistant.io/blog/2016/10/25/explaining-the-updater/ updater: # Optional, allows Home Assistant developers to focus on popular components. # include_used_components: true # Discover some devices automatically discovery: # Allows you to issue voice commands from the frontend in enabled browsers conversation: # Enables support for tracking state changes over time history: # View all events in a logbook logbook: # Enables a map showing the location of tracked devices map: # Track the sun sun: # Sensors sensor: # Weather prediction - platform: yr # Text to speech tts: - platform: google # Cloud cloud: #switch: -platform: broadlink host: 192.168.x.xx mac: '34:xx:34:xx:ee:xx' type: rm3_pro_plus switches: Shelf_light: friendly_name: "Shelf Light" command_on: 'JgC8AAABL5IWEBUQFhAVEBYQFRAWEBUQFjQVNRU1FTUVEBY0FTUVNRU0FjQWEBURFREVEBUQFREVERUQFTQWNBY0FjQVNRU1FQAFQAABL0cWAAxWAAEvRxYADFYAAS5HFgAMVgABLkcWAAxWAAEtSBUADFYAAS5IFQAMVgABLUgVAAxXAAEtRxYABA4JAAg' command_off: 'JgCYAAABLpIVERUQFRAWEBUQFhAVEBURFTQWNBU1FTUVEBY0FTUVNRUQFTUVEBYQFRAVERUQFRAWNBURFTQWNBY0FTUVNRU0FgAFQQABLkgVAAxFAAEtSRUADEkAAS9HFgAMPQABLkgVAAxCAAEuSBUADFgAAS1IFQAMWAABLUkUAAxYAAEsSRUADFgAAS1IFQAMWAABLUgVAA0F' group: !include groups.yaml automation: !include automations.yaml script: !include scripts.yaml panel_iframe: configurator: title: Configurator icon: mdi:wrench url: http://192.168.0.33:3218
