Hey Forum
totally newbee here.
I have recieved my new HA blue and already i have forgot my password.
Is there a way to factory reset the blue, so I can start from the beginning again?
Regards Lillelars
Hey Forum
Regards Lillelars
Hello Lillelars,
I’m in the same situation and also a newbie. Did you figure out a solution for this?
Thanks,
Sid
You can reflash the emmc but it’s probably going to be easier to reset the password assuming you have a keyboard and monitor to attach to it.
Once you do so you will see the ha cli with the ha> prompt.
Enter auth reset --username "YourUserName" --password "Your New Password"
https://www.home-assistant.io/docs/locked_out/#to-reset-a-users-password-via-console
To reflash completely using a USB cable, the instructions are here: https://www.home-assistant.io/common-tasks/os#flashing-an-odroid-n2
Hello
Please help me.
The only thing I see in the console is:
Welcome to Home Assistant
home assistant login:
What should I do?
auth reset… reply with Error : Unknown error , see supervisor
You would then enter “su logs” to see what the supervisor shows
