I need help - desperately!
I just plugged in my second HA Green after returning the first one that never completed the boot process because of both getting stuck repeatedly with this error:
24-12-14 14:43:13 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/green-homeassistant:2024.12.3: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.12.3&fromImage=ghcr.io%2Fhome-assistant%2Fgreen-homeassistant&platform=linux%2Farm64: Internal Server Error (“Get “https://ghcr.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”)
I am using 8.8.8.8 as the router DNS (I read where some ISP DNS’s cause problems) and turned off my second instance of HA running on my Synology NAS before starting the new hub so it couldn’t interfere.
I really need some help on this from this fantastic community - please!
Here is the complete log from the start of boot up until it gets stuck looking for ghcr.io:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[19:30:33] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[19:30:33] INFO: Starting local supervisor watchdog…
24-12-14 19:30:38 INFO (MainThread) [main] Initializing Supervisor setup
24-12-14 19:30:38 INFO (MainThread) [supervisor.docker.network] Can’t find Supervisor network, creating a new network
24-12-14 19:30:38 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: green
24-12-14 19:30:38 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor Package aarch64-hassio-supervisor · GitHub with version 2024.03.0
24-12-14 19:30:38 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
24-12-14 19:30:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
24-12-14 19:30:38 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-12-14 19:30:38 INFO (MainThread) [main] Setting up Supervisor
24-12-14 19:30:39 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
24-12-14 19:30:39 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
24-12-14 19:30:39 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
24-12-14 19:30:39 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
24-12-14 19:30:39 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
24-12-14 19:30:39 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
24-12-14 19:30:39 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
24-12-14 19:30:39 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
24-12-14 19:30:39 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
24-12-14 19:30:39 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
24-12-14 19:30:39 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
24-12-14 19:30:40 INFO (MainThread) [supervisor.host.services] Updating service information
24-12-14 19:30:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-12-14 19:30:40 WARNING (SyncWorker_0) [supervisor.host.sound] Can’t update PulseAudio data: Failed to connect to pulseaudio server
24-12-14 19:30:40 INFO (MainThread) [supervisor.host.network] Updating local network information
24-12-14 19:30:40 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
24-12-14 14:30:40 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
24-12-14 14:30:40 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-12-14 14:30:40 INFO (MainThread) [supervisor.docker.interface] Found Package aarch64-hassio-cli · GitHub versions: [<AwesomeVersion CalVer ‘2024.03.1’>]
24-12-14 14:30:40 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-cli · GitHub with version 2024.03.1
24-12-14 14:30:40 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
24-12-14 14:30:41 INFO (MainThread) [supervisor.docker.cli] Starting CLI Package aarch64-hassio-cli · GitHub with version 2024.03.1 - 172.30.32.5
24-12-14 14:30:41 INFO (MainThread) [supervisor.docker.interface] Found Package aarch64-hassio-dns · GitHub versions: [<AwesomeVersion CalVer ‘2024.03.0’>]
24-12-14 14:30:41 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-dns · GitHub with version 2024.03.0
24-12-14 14:30:41 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
24-12-14 14:30:42 INFO (MainThread) [supervisor.docker.dns] Starting DNS Package aarch64-hassio-dns · GitHub with version 2024.03.0 - 172.30.32.3
24-12-14 14:30:42 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
24-12-14 14:30:42 INFO (MainThread) [supervisor.docker.interface] Found Package aarch64-hassio-audio · GitHub versions: [<AwesomeVersion CalVer ‘2023.12.0’>]
24-12-14 14:30:42 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-audio · GitHub with version 2023.12.0
24-12-14 14:30:42 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
24-12-14 14:30:43 INFO (MainThread) [supervisor.docker.audio] Starting Audio Package aarch64-hassio-audio · GitHub with version 2023.12.0 - 172.30.32.4
24-12-14 14:30:43 INFO (MainThread) [supervisor.docker.interface] Found Package aarch64-hassio-observer · GitHub versions: [<AwesomeVersion CalVer ‘2023.06.0’>]
24-12-14 14:30:43 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-observer · GitHub with version 2023.06.0
24-12-14 14:30:43 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
24-12-14 14:30:44 INFO (MainThread) [supervisor.docker.observer] Starting Observer Package aarch64-hassio-observer · GitHub with version 2023.06.0 - 172.30.32.6
24-12-14 14:30:44 INFO (MainThread) [supervisor.docker.interface] Found Package aarch64-hassio-multicast · GitHub versions: [<AwesomeVersion CalVer ‘2024.03.0’>]
24-12-14 14:30:44 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-multicast · GitHub with version 2024.03.0
24-12-14 14:30:44 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
24-12-14 14:30:45 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast Package aarch64-hassio-multicast · GitHub with version 2024.03.0 - Host
24-12-14 14:30:45 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
24-12-14 14:30:45 INFO (MainThread) [supervisor.docker.interface] No version found for Package green-homeassistant · GitHub
24-12-14 14:30:45 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image Package green-homeassistant · GitHub found.
24-12-14 14:30:45 INFO (MainThread) [supervisor.docker.interface] Attaching to Package green-homeassistant · GitHub with version landingpage
24-12-14 14:30:45 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
24-12-14 14:30:45 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
24-12-14 14:30:45 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
24-12-14 14:30:46 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant Package green-homeassistant · GitHub with version landingpage
24-12-14 14:30:46 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
24-12-14 14:30:46 INFO (MainThread) [supervisor.store.git] Cloning add-on GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
24-12-14 14:30:46 INFO (MainThread) [supervisor.store.git] Cloning add-on GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
24-12-14 14:30:46 INFO (MainThread) [supervisor.store.git] Cloning add-on GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on repository
24-12-14 14:30:52 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
24-12-14 14:30:52 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
24-12-14 14:30:52 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
24-12-14 14:30:52 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
24-12-14 14:30:52 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
24-12-14 14:30:52 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
24-12-14 14:30:52 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-12-14 14:30:52 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
24-12-14 14:30:52 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-12-14 14:30:52 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not running - setup
24-12-14 14:30:52 INFO (MainThread) [main] Running Supervisor
24-12-14 14:30:52 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
24-12-14 14:30:52 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
24-12-14 14:30:52 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
24-12-14 14:30:52 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2024.11.4
24-12-14 14:30:52 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package aarch64-hassio-supervisor · GitHub with tag 2024.11.4.
24-12-14 14:37:08 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.11.4: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.11.4&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error (“Get “https://ghcr.io/v2/”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)”)
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.module] Create new issue update_failed - supervisor / None
24-12-14 14:37:08 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can’t install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.11.4: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.11.4&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error (“Get “https://ghcr.io/v2/”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)”)
24-12-14 14:37:08 CRITICAL (MainThread) [supervisor.core] Can’t update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
24-12-14 14:37:08 INFO (MainThread) [supervisor.addons.manager] Phase ‘initialize’ starting 0 add-ons
24-12-14 14:37:08 INFO (MainThread) [supervisor.addons.manager] Phase ‘system’ starting 0 add-ons
24-12-14 14:37:08 INFO (MainThread) [supervisor.addons.manager] Phase ‘services’ starting 0 add-ons
24-12-14 14:37:08 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
24-12-14 14:37:08 INFO (MainThread) [supervisor.addons.manager] Phase ‘application’ starting 0 add-ons
24-12-14 14:37:08 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
24-12-14 14:37:08 INFO (MainThread) [supervisor.core] Supervisor is up and running
24-12-14 14:37:08 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
24-12-14 14:37:08 INFO (MainThread) [supervisor.docker.interface] Updating image Package green-homeassistant · GitHub to Package green-homeassistant · GitHub
24-12-14 14:37:08 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package green-homeassistant · GitHub with tag 2024.12.3.
24-12-14 14:37:08 INFO (MainThread) [supervisor.host.info] Updating local host information
24-12-14 14:37:08 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.check] System checks complete
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
24-12-14 14:37:08 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
24-12-14 14:37:08 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not healthy - supervisor
24-12-14 14:37:09 INFO (MainThread) [supervisor.host.services] Updating service information
24-12-14 14:37:09 INFO (MainThread) [supervisor.host.network] Updating local network information
24-12-14 14:37:09 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
24-12-14 14:37:09 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-12-14 14:43:13 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
24-12-14 14:43:43 INFO (MainThread) [supervisor.docker.interface] Updating image Package green-homeassistant · GitHub to Package green-homeassistant · GitHub
24-12-14 14:43:43 INFO (MainThread) [supervisor.docker.interface] Downloading docker image Package green-homeassistant · GitHub with tag 2024.12.3.
