New HA server running Ryzen + Proxmox
After long thinking and making some checkin etc. Decided to replace my ol RPI 4 with a powerful mini server, so this time my HA will run a blazing speed even when I compare with my Synology.
OS:
Proxmox
Debian 10.8 with HA Supervised
Specs:
ASRock MiniDesktop 300X running Ryzen 4570G
64GB memory 3200 Mhz (2 slot 32GB)
1TB NVME SSD Drive
Wifi Module + BT Module
Total Damage: Plus Minus USD 1.000 give or take
Still have a lot to put into maybe replacing the original Cooling with something better.
$100 ??? excellent price…I assume used??
sorry my bad… missing 0
What’s the power consumption ?
Nice! Do you anything else then just HA on it?
For cooling, i would get a new case and a beefy air cooler or AIO cooler, but its not easy to get a case with these mounting holes.
That will beat the rpi hands down. Hell there was time when that would have run the entire internet.
max out at 65w I believe
Off course… will run Windows 10 and maybe hackintosh Catalina… hahahahahaha
Well the only options is actual noctuna cooling system and one other thing. I forget since the case is very small
hhehehehe… that is very true…
