Hi Everyone,
New HA user here been using it about a week and I have been super impressed. I do already have a smartthings Hub and Hubitat Hub as well as some hue lights, I am running HA O\S on Hyper-V running on a small HP micro server.
My Smartthings and Hubitat are using hub connect which is allowing me to share some devices from Smartthings to Hubitat, smartthings has no automations it us literally just so I can use some wifi plugs that are only supports on smartthings, all my automations are currently set up on the hubitat hub using webcore and things do seem to work pretty well for me but there is always room for improvement.
As well as these 2 hubs sharing devices they also share any mode changes, so if presence for all users changed to not present then away mode would be set and synced between the 2 hubs, same for home mode, night mode ect.
Now reading online it seems HA does not have the functionality of using these modes but from what I can gather I should be using input Booleans instead, so I have created the following input bools
Ideally what I am trying to achieve here to have the same modes as I have on the other systems and have them syncing up between the hubs. When one of above input bools is true\on the rest should be false\off and was wondering if anyone had managed to achieve anything similar?
Currently I am using jason0x43 - hacs-hubitat Integration which is working great. I eventually want to move all of my automations away from WebCore on the Hubitat hub and move them over to HA and just use the Hubitat hub as a ZigBee co-ordinator but I am currently finding the learning curve here very steep compare to the hubitat and smart things systems, I have been running HA for around 2 weeks now and it took me most of that time to get all my devices imported and working on the dashboard but I have yet still to build any automations or scenes.
Any advice or input is greatly appreciated!
Edit: I did mean to say I can see these sensors but not sure how to utilize them or the best way to start building an automation to achieve what I am trying to do.
Also it needs to work both ways as one I move some automation into HA they will be disabled in Webcore on Hubitat
