New HASSIO ssh question
do you guys know how to access the Pi3 again via SSH not the new SSH but the old SSH where you can run sudo and install packages… I Needed to install other packages like pihole and etc…
Im currently running resinos-hassio-1.1-raspberrypi3.img… I’m able to run the add on SSH but i prefer the old version so that i can do more stuff
Dear Jaysix79,
To my understanding this is not possible under hass.io and you need to revert back to hassbian or AIO installations.
I am still switching from the one to the other. Hass.io has the ease of install (when it works) but you loose the flexibility.
Kind regards
An interesting topic on this subject: Should i move to Hass.io
Follow these instructions: https://home-assistant.io/developers/hassio/debugging/
You still won’t get full root access like a standard OS - I believe that is impossible with ResinOS. but this debugging SSH session does allow you to access docker commands directly as well as other high-level functions.
I’m switching back to the old ways… i like the old flexibility
now the question is where is the old hassbian instruction or the AIO
For hassbian https://home-assistant.io/docs/installation/hassbian/installation/
And for AIO https://home-assistant.io/docs/installation/raspberry-pi-all-in-one/
