My Yale Zwave smart lock has been working flawlessly for 1 week since I installed it. I’ve only had HA for about 2 weeks and only have 3 nodes (front door lock, and 2 light bulbs).
I even got an automation working for when my daughter opens the door it will send me an iOS notification via the app. Works great.
Suddenly though this evening, it will only update it’s status with the system but I can’t send lock or unlock commands to it, not through Google Home voice commands or just the entries. I’m assuming it has something to do with it being a secure node.
I set up zwave through the integrations button in HassIO. I went and found a configuration document called core.config_entries . In it I found the network key which I read is necessary for secure nodes. It all looks correct to me based upon my research before I bought the lock.
"connection_class": "local_push",
"data": {
"network_key": "0x97, 0xBF, 0x5F, 0xA3, 0x81, 0xD3, 0x4A, 0x99, 0xE8, 0x8E, 0x8E, 0x52, 0xFD, 0xB2, 0x75, 0x66",
"usb_path": "/dev/ttyUSB0"
"domain": "zwave",
"entry_id": "47f3f8f7319f4ab5810af1807d6c2bb4",
"options": {},
"source": "user",
"title": "Z-Wave",
"version": 1
I went into configuration and zwave and looked at the OZW log and this is what it reads.
Does anyone have a thought on how to troubleshoot this? Earlier this evening I rebooted HassIO and then the lock worked for about an hour, it stopped working again and thought I’d come here and ask for some advice. Hope you all have some. I’m only 3 nodes into Zwave and I already have a failure within a week…hope this isn’t indicative of the overall use of the system.
