New Home Assistant addon to run FRStackWebAPI
I’ve created a simple Home Assistant addon to run FRStackWebAPI in a container. I did it as I have a remote shack and it has a Pi 4 running Home Assistant to supervise/control the shack. I’ve only tested on amd64 and aarch64 architectures, but it should work on armhf and armv7.
The addon can be found here.
Currently, it will build on your instance. You shouldn’t notice anything other than a longer installation time. If there is sufficient demand, I’ll sort out the builder to create an image.
If there are any issues, please raise them as an issue on GitHub.
