New Home Assistant Green installation. I followed the recommended procedure of connecting ethernet followed by power.
White LED is on. Yellow and Green are blinking a complex pattern, which would feel like an error message. Pattern does have one green blink, then two yellow blinks, which does appear to repeat, but there appears to be much more to the pattern at times.
Only static on HDMI port. Screen goes black, then static. Repeat.
HA Green has a sub documentation site that explains the LEDs, yours sounds perfectly normal. I turned off the white and the green and just left the heartbeat going.
Have you tried either: http://homeassistant:8123/
or http://IP address of HA:8123/ check your dhcp on your main router or what ever is handing out IP addresses.
Could be how your have the network setup as why your not seeing it
I get a connection rejected from wifi connected browsers and another machine ethernet connected browsers. Android Phone via HA app times out. Browser on phone fails.
I can see device from router with correct ip address 192.168.. and name homeassistant.
I have tried hard reset of Green box via holding power button and connecting power.
Thinking a reset of router may work. I am figuring this is a router issue at this point. Running out of ideas and internet clues. I will start fresh tomorrow, powering everything down and documenting feedback.
I had a mini PC working with HA, while waiting for HA Green. Mini PC had wifi and ethernet. So router was working. This may of confused something. A stretch…
Much more interesting question is why does green blink this “much” when HA should be idling?
Nothing is happening around my network or within HA but a flashing LED doesn’t really indicate “I am not doing anything”.
