New Home Assistant install and no Hass.io (Docker)
I have no idea what your problem is. You started off this conversation by asking if it’s possible to run deconz without hassio, and you stated you installed home assistant in a python virtual environment.
You said you wanted to integrate deconz…so are you running deconz? What directory are you trying to whitelist? Where is this file you are trying to access?
What do you think whitelisting is going to do for you?
I installed deconz addon. I cant see 'usr\share\deCONZ\zcl\general.xml ’ path in hass.io
All I want is to add custom cluster in deconz UI as given in above image.
But you started this conversation by stating that you installed home assistant and not hassio…SMH
deconz is running in a DIFFERENT docker container, and you will not see files INSIDE that docker container unless they are mapped via bind mounts. You would have to talk to the developer of the add-on to find out what is mapped where.
OK.
Whitelisting a directory inside home assistant doesn’t accomplish this.
