I went into this knowing nothing, beyond the typical network wiring knowledge and skills I already had. Then I went looking for wire…
Once I had a list of EVERY type of wire and its properties, I needed to find out which would work best for my application, yoursof course may not be the same. I chose the red 18 gauge wire, which is rated for higher voltage, and of course higher current, and if I chose to repurpose wire pairs for power it is not a problem. It is also rated for higher temps, and my attic gets HOT. I got 8, 4, and 2 conductor, and VERY quickly ran out. Only then did I have a better idea of exactly how much I would need, and that the resistance and capacitance may be a problem with that much wire.
The average capacitance on the 8-pair is fairly low, but still about double my measurements of the CAT6A I purchased for this work. The install manual for the security panel has notes about the max length wiring you can do with each gauge and pair count, within the confines of security wire. You can extrapolate the capacitance limit of the panel with these numbers if you do the math correctly.
One of the reasons that security companies love wireless transmitters (other than the margin) is that their installers do not need to carry fancy multimeters or know the math and physics requirements that arise when dealing with system capacitance for large wired installations. The installers from the security company that did our house did not even have a multimeter. They also did not correctly calculate the current requirements of the zone expanders and keypads, which were WAY over the budget of the onboard power supply of the panel. I kind of already knew this after the company initially quoted a parts list which did not include an additional power supply, but was fully prepared and willing to correct any mistakes they made along the way.
I was also the one who gave them the full requirements list, which had local home automation in mind, so there were far more zones than they were probably dealing with in a typical residential install. When a glassbreak sensor trips, it holds a relay for 4 seconds, and if several trip at the same time, they can pull a substantial amount of current, which also occurs during the siren alert as well as the pezio sirens on both keypads, and this is one scenario they did not consider, as the idle draw for the system was JUST within the limit, but the alarm condition was not.
The issue with induced voltage from high voltage AC proximity is twofold. 1, it can damage the panel and zone expanders. 2 it can cause false alarms. So I did some insane work to get that as low as possible, and had to relocate the wiring that powered my doorbell transformer as well as the lights in my utility room. On a new build this should not be an issue since they should not be anywhere near eachother unless someone made a mistake.
The other issue with 22 gauge wire is that if you need to push it, it can just fold over itself. Running 8 conductor 8 gauge through conduit is FAR easier, though not as easy as ethernet… once again my work was all retrofit so this is probably not an issue for you. It all depends on the house layout and where you want sensors both now and in the future.
If you get the opportunity, do not go with wifi switches for primary lighting control. Either do Lutron which is 433mhz, or use centralized control for low voltage lighting. 2.4GHz has very poor RSSI from inside a wall for one, and there are just to many sources of interference. Plus their current draw is high in order to stay constantly connected to the network. There are more reasons beyond that, but those are the big ones.
I am using BlueCherry in docker for NVR, and it is working great and has solid motion detection, in addition to the alternate motion detection on the camera itself which triggers an ONVIF command (that I am not using). I looked at Reolink and at the time rejected them, I do not remember why. All the cameras I have now can take a hit from a baseball bat and still function, I think none of the their cameras were vandal resistant, and none of their cameras met the environmental requirements (temp) for outdoor use. I do not have outdoor cameras installed yet, but when I do they will all be Axis cameras.
There are so many cool things that can be done with energy monitoring. Beyond tracing down vampire devices or malfunctioning power supplys, the main thing is in problem detection and event notifications, for example.
Your air conditioner is “on” per the thermostat, but the power draw is far too low… because the capacitor failed and the compressor will no longer start. This can detect the problem an hour or more before temperature based automations can. During the summer I can imaging failed aircon can be a BIG problem, this happened to me, luckily we were out for only a few hours, but the interior temp still went up to 89F, and we have pets!
You set the house alarm to away, but there is power draw on the range or oven. Did you mean to leave it on, you may be cooking a roast… or maybe you just forgot to turn something off and are going to start a fire. You can easily be warned of a potential issue with power monitoring.
The washer or drier has finished its cycle, the power draw drops below threshold for a period of time, notifications can be automated, “washer finished but drier did not start within 10 mins”. Dishwasher can also trigger alert when cycle is complete, no need for “smart” devices with their proprietary cloud based connection that has no open API.
