Hi everybody,
I am considering a new computer as my home server. My initial thoughts were to buy the same one I use as my desktop pc (intel nuc, specs below), but perhaps this is not enough (or too much), so I was hoping to get some input on what to buy.
My current home server is a beelink
(similar to intel nuc) with these specs
- RAM 8GB
- SDA 100GB (not enough!)
- Intel Pentium Silver N5000 CPU @ 1.10Ghz
- running
debian 4.9.210
- nothing connected / headless setup
Home Assistant runs fine on it, so do all the other services:
bare metal:
- zigbee2mqtt
- mosquitto server
dockerized
- Home Assistant
- Grocy
- Dokuwiki
- appdaemon
- gitea
- mary-tts
- (another) mosquitto server
- nginx
- bookstack (currently replacing with dokuwiki)
- mariadb
- chronograph
- influxdb
- adb server
- phpmyadmin
- portainer
I have only about 2% disk space left, and memery is usually like this
Mem: 7.6GB total 2.1G used 1.2G free 53M shared 4.3 buff/cache 5.2G available
Swap: 7.8G total 41M used 7.8G free
top
shows that my CPUs usually have a load avery between .5 and .64 (sometimes spiking up to 100% for a couple of seconds).
The home server definitely needs a new hdd/sdd for sure, but I was thinking of buying a completely new device, so that I could use the current home server as a test server, while all services that I need to run can be on the new device.
My desktop pc is an intel nuc i7
- RAM 32GB
- sdd 260GB
- Intel Core i7-8809G CPU @ 3.10GHz
- running
5.7.4-arch1-1
- two monitors, keyboard, mouse, etc. connected
I am considering this very same model for the new home server; the only thing I am not really sure about is the graphics card, which is a Radeon RX Vega
. I don’t know much about graphics cards, but I am pretty sure that I won’t need this card for running a headless home server. Is there some alternative with similar specs, but without a powerful graphics card that you can recommend (perhaps even from personal experience)?
Guess I should mention that I would even go for a small “actual” server (like, a rack unit); I have a small rack and got space for 1-2HE. But I wouldn’t know where to begin, and I am not sure about power consumption. Both the beelink and my intel nuc run at 100W; the servers I looked at all (HP Proliant, for example) have two times 750W, which is way too much, considering that I this is for personal use only, but has to run 24/7. I don’t want to spend 15 times as much on energy when running something like this.
However! If there is a decent rack server with > 32GB RAM, a fast processor, perhaps a system sdd and storage hdd(s), I would go for that. Otherwise, something like the intel nuc would be fine as well.
What do you use? What can you recommend? Thank you for your input
