New House Built Around Zigbee... ZHA Errors SLZB-06
Hi Community,
So… I’ve built a new house (UK). The electrics have all been wired based on using home assistant and zigbee. There are no light switches. Relevance of that is that I need the basic setup to be reliable and low (no) maintenance.
Early days but so far it is neither. The system is vital and not sure what the backup plan is!! From the trawling I have done on the community there are some smart people here so hoping there is an easy fix.
There is a whole house WIFI and Ethernet network. There is a server room. In that room there is a HA Green Box. Working nicely as far as I can see. Completely up to date.
Originally I had the Sky Connect dongle in the server room, but in hindsight that was never really going to be reliable as was in a remote-ish locked room in corner of house.
After some trawling, I purchased the SMLIGHT SLZB-06P7. Full system reset and that is now connected over POE right in the middle of the house. HA found the dongle. All devices re-paired nicely. Using ZHA.
Now, almost every day (3 weeks in) at some seemingly random point during the day or night everything connected to that SLZB becomes unavailable on the dashboard and cannot be controlled. The ZHA card says ‘setup failed’. The only way of getting things back is to reset the SLZB either via it’s web interface or through the card in HA. Resetting ZHA does not work, the first time it happened I reset the Hub and that didn’t clear the error either.
The SLZB is up to date, originally I thought the blackout coincided with the dongle auto-updating; but it does not. I reached out to SMLIGHT a couple of weeks ago but no response.
From checking the logs after these blackouts it seems to be a similar recurring issue (below). There are some older threads with similar, but just seemed to be an HA update resolved it in those cases.
Logger: zigpy.application
Source: /usr/local/lib/python3.12/site-packages/zigpy/application.py:668
First occurred: 31 October 2024 at 07:14:52 (2 occurrences)
Last logged: 1 November 2024 at 13:37:38
Watchdog failure
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1065, in request
    response = await response_future
asyncio.exceptions.CancelledError
  File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 666, in _watchdog_loop
    await self.watchdog_feed()
  File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 652, in watchdog_feed
    await self._watchdog_feed()
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 628, in _watchdog_feed
    await self._znp.request(c.SYS.Ping.Req())
  File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1061, in request
    async with async_timeout.timeout(
  File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 141, in __aexit__
    self._do_exit(exc_type)
  File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 228, in _do_exit
    raise asyncio.TimeoutError
TimeoutError"
Any ideas anybody? Really hoping the Community can assist. Any further info required, please let me know!!
Thanks in advance and apologies for the long message.
Sounds like an interference problem. There are many writeups and videos on how to build a solid zigbee network, e.g. wifi / zigbee channel selection, supplemental routers, etc.
If the entire network is dropping, I’d guess a bad coordinator and try swapping that out.
Less likely, but worth checking since it appears “random” - check your major appliances to see if any are running and causing the drop. Microwaves are notorious for emitting RFI in the same frequency band used by 2.4 Ghz wifi and Zigbee.
solstyce9, thanks for your quick response and understood. Naively I thought Zigbee ZHA et al. would be sufficiently ‘robust’ so that stability/temporary interference issues wouldn’t bring the system down. Or as you say I may just be unlucky with a faulty coordinator.
I am also a novice.
I have just written an automation to press the ‘reset’ on the coordinator when one of the lights becomes Unavailable or Unknown for more than 2mins. There is a counter so that I can monitor how often that triggers. Not elegant but I’ll have to see if that works… Seems like I could replace coordinator, re-channel the whole system or whatever and still end up with similar blackouts because of some other quirk.
Thanks again for response.
Hello.
I recently got into Zigbee and bought a SLZB-06, a few bulbs and a motion sensor.
I’ve only been using them for a couple of weeks but have had to restart the SLZB-06 at least a few times.
I just started looking into the issue and any potential fixes and came across your post.
Figured I could list my config here in case you or anyone else can see anything related that may be causing our issue:
SLZB-06:
https://www.aliexpress.us/item/3256804944165230.html
|Radiomodule mode:|Zigbee coordinator|
|Connection mode:|Ethernet mode|
|Ethernet connected:|Yes|
|WiFi client turned On:|No|
|WiFi AP turned On:|No|
Firmware version: 20240710 v2.5.6
  • Core2024.10.4
  • Supervisor2024.10.3
  • Operating System13.2
  • Frontend20241002.4
I’m glad to provide any other info if needed.
EDIT:
I implemented the restart and counter automation that you mentioned.
Additionally there was a firmware update for the SLZB-06 within the last week.
Anyway the counter is showing there were no restarts in the last 5 days and everything has been working flawlessly.
Not sure if the firmware has fixed something or not.
Glad to hear your issues resolved (hopefully still the case).
Mine have gone from bad to worse.
Help desperately needed.
Recap, house built assuming a reliable zigbee setup (no light switches). Regular and random ZHA failures since install.
The issues in first post continued same format, despite carrying out all potential interference based remedies (changing AP channels, etc. etc.). Until the coordinator itself completely died. Wouldn’t switch on/off, restart, or respond at all; either via HA or its’ own interface.
All issues had to be the coordinator, right? Smlight offered a replacement, in the time it took them to respond I had ordered and received an SLZB-06 (not the P7 version previously) hoping that surely a downgrade would be more reliable.
A couple of days ago I completed a full restart of the system with this new coordinator. 70 devices manually re-paired (the migration procedure did not work).
All running ok for a couple of days… until some time early this morning the ZHA integration fails. Couldn’t switch the lights on this morning. Only thing that worked was a zigbee core restart on the SLZB.
Here we go again.
I am literally at my wits end with this now.
There must be someone proficient in these systems in the UK that could assist me…?? Are all the smlight products rubbish? Does anybody have a system running circa 70 devices reliably?
Have no idea what else to do now.
The (I assume) fatal error from 3.27am this morning.
Logger: zigpy_znp.uart
Source: /usr/local/lib/python3.13/site-packages/zigpy_znp/uart.py:58
First occurred: 21 January 2025 at 16:15:14 (44 occurrences)
Last logged: 03:27:42
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x43\x19\x84'))
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x16\xE1\x84'))
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x46\x75\x84'))
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x63\xE6\x84'))
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\xA4\x3A\x84'))
  File "/usr/local/lib/python3.13/site-packages/zigpy_znp/types/commands.py", line 417, in from_frame
    params[param.name], data = param.type.deserialize(data)
  File "/usr/local/lib/python3.13/site-packages/zigpy/types/struct.py", line 319, in deserialize
    value, data = field_type.deserialize(data)
  File "/usr/local/lib/python3.13/site-packages/zigpy/types/basic.py", line 199, in deserialize
    raise ValueError(f"Data is too short to contain {byte_size} bytes")
ValueError: Data is too short to contain 1 bytes
  File "/usr/local/lib/python3.13/site-packages/zigpy_znp/uart.py", line 56, in data_received
    self._api.frame_received(frame.payload)
  File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 854, in frame_received
    command = command_cls.from_frame(frame, align=self.nvram.align_structs)
  File "/usr/local/lib/python3.13/site-packages/zigpy_znp/types/commands.py", line 424, in from_frame
    raise ValueError(
    ...<2 lines>...
ValueError: Frame data is truncated (parsed {'Src': 0x60C6, 'Status': <Status.NOT_SUPPORTED: 132>}), required parameter remains: Param(name='Routes', type=<class 'zigpy.zdo.types.Routes'>, description='Routes', optional=False)
OK, just done last thing I can think of.
Moved HA Green hub to middle of house, to avoid needing POE coordinator. Migrated to the SkyConnect. (hats off, that process worked flawlessly).
Let’s see if a HA Green, ZHA and ZBT-1 system is reliable.
And what has been the status of the SkyConnect?
OK, has been a few weeks now, apologies for the late response - really didn’t want to tempt fate…
Not a single error to date using solely the SkyConnect.
So, fairly definitively, in my experience the Smlight products do not function adequately; I have tried three of their devices (two different models, SLZB-06p7 and SLZB-06) and all consistently create same fatal errors. I tried both POE and USB powered/wifi.
I can only assume that the (seemingly knowledgeable) YouTube reviewers I initially watched didn’t try these devices for more than a few days.
I just wanted to add an update that my SLZB-06 has been working pretty reliably since the last firmware update.
I do not however have 70+ devices connected to it like you do. Only about 20 or so.
I do have some issues with some Tuya smart knobs but I think it’s more of a problem with them than the controller or my HA setup.
Anyway thanks for updating on your experience as well.
