New hubitat device missing from HA Hubitat device integration list
I recently bought an Aqara Wireless Mini Switch (https://a.co/d/dOO5G19) and was able to add it to my Hubitat hub. It uses a custom driver which I imported just fine. The button press is registering just fine in the logs in the Hubitat hub as well.
The issue is that it’s not showing up in my hosted HA environment.
Here is my current list:
Things I’ve tried:
Updates for both platforms (HA/Hub)
Full reboots for both
Re-configured the hubitat integration
This is what happens when I go to reconfigure, it should show up here but it’s not.
So I’m stuck at what to do at this point. Has anyone had this problem?
The Zigbee section in the Home Assistant community is the wrong place to post problems about Hubitat integration as Hubitat abstracts the device so its original protocol does not matter (e.i. as far as Home Assistant is concerned it could be any other type of device). So you should instead post to the third-party integration section → Third party integrations - Home Assistant Community
Great thanks.
