Hi
I am slowly integrating a proprietary automation system with HomeAssistant. So far, with much help here, I have lights (with platform template with webhook for maintaining state and rest_commands to control) and room occupancy, door & window state (input_boolean) working well (~10s of entities, 10s of calls an hour). I use this to present the house through the companion app.
Next I’d like to sync the HVAC controls for each room/area/zone (10 zones). Each object in the other controller has various attributes I’d like to track (including room temp, set point temp, call-for-heat) and various things I’d like to control (services in HA parlance?) including triggering change of set point profile and forcing heat on for a period (like a boost).
The general thermostat entity looks interesting, but is quite different to the HVAC object I want to reflect in HA. The HVAC object has 5 states (Heat, Cool, Off, Disable, Fallback)
I’ve had a look at the source for the thermostat and it is beyond me to create a new entity that way.
Is it possible to define a new object/ entity for each heat zone with attributes in YAML which I can then update using webhooks and rest command to send instructions? Something like a blueprint but for an entity rather than an automation??
Is defining a new independent entity for each thing I want to track and control going to be simpler? How would I associate this collection of entities in a heat zone to an Area to make the display in a card easier?
Are there other/better ways to approach this?
TIA
