Hello and I will start with I am a newcomer to HA. Looking forward to continuing to explore it.
I currently have a Dell T1700 Precision Workstation running as a plex server and chose to take advantage of it running all the time to house a Home Assistant installation. I’m running the HA via a Hyper-V virtual machine.
I previously set it up per the instructions and stared to add an integration with my Smartthings hub. I made the private key and all that. Eventaully added a trial of the Nabu Casa for remote access, but then started to explore running without that and using duckdns.org add-on.
My initial install was actually as a service on a “dietpi” VM. I then killed that and transitioned to the HA VM, because it was more full featured. I ended up killing off the HA VM I initially made as a test and rebuilt it from scratch.
Now, when trying to add the Smartthings integration I get the error about a webhook. I’ve done searching and found this: https://pypi.org/project/hass-smartthings-remove/
But, this leaves me with a few unanswered questions:
- Shouldn’t this have been in the old now deleted VM?
- Or is this somehow housed locally on the host machine?
- Depending on the answer above, it’s unclear to me where to run this.
Any help would be appreciated.
