1.Download the Hassbian image (364 MB)
2.Use Etcher to flash the image to your SD card
3.Ensure your Raspberry Pi has wired access to the internet.
4.Insert SD card to Raspberry Pi and turn it on.
need type the following two commands into the SSH console?
Not using hassbian, but “install_homeassistant.service” feels wrong. I would try typing sudo systemctl enable (without enter after) and press the tab key twice to expand the list of services.
… but nothing happend? and this with 2 SD cards.
I checked the status of install and it was complete, and I check ip:8123 for the hass instance but it is not up. So now I run: sudo journalctl -fu [email protected] and see:
-- Logs begin at Fri 2017-05-05 18:30:24 UTC. --
May 05 18:32:42 hassbian hass[799]: from jinja2.environment import Environment, Template
May 05 18:32:42 hassbian hass[799]: File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/environment.py", line 15, in <module>
May 05 18:32:42 hassbian hass[799]: from jinja2 import nodes
May 05 18:32:42 hassbian hass[799]: File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/nodes.py", line 19, in <module>
May 05 18:32:42 hassbian hass[799]: from jinja2.utils import Markup
May 05 18:32:42 hassbian hass[799]: File "/srv/homeassistant/lib/python3.4/site-packages/jinja2/utils.py", line 624, in <module>
May 05 18:32:42 hassbian hass[799]: from markupsafe import Markup, escape, soft_unicode
May 05 18:32:42 hassbian hass[799]: ImportError: No module named 'markupsafe'
May 05 18:32:42 hassbian systemd[1]: [email protected]: main process exited, code=exited, status=1/FAILURE
May 05 18:32:42 hassbian systemd[1]: Unit [email protected] entered failed state.
