Hello there,
I see there is a issue logged highlighting the problem: IMAP integration body limited to 2048, was not an issue for imap_email_content · Issue #93138 · home-assistant/core · GitHub and a PR to provide a option that can be used to address it by providing a option to allow for longer message size in the event content: Add advanced imap option to set custom event max message size #93163.
From what I can see I think the update has been made(?), but I can’t see in the IMAP documentation how to use the new option. It does hint in the IMAP documentation that message length can be something other than default on line that says: The email body text
of the message (by default, only the first 2048 bytes will be available.).
Could someone point out where in the documentation I missed the info on the new option, and maybe provide me an example of how my code below can be modified to increase the message/text length?
Thank you
- trigger:
- platform: event
event_type: "imap_content"
- name: test_imap_sensor
state: "{{ trigger.event.data['subject'] }}"
attributes:
Message: "{{ trigger.event.data['text'] }}"
Server: "{{ trigger.event.data['server'] }}"
Username: "{{ trigger.event.data['username'] }}"
Search: "{{ trigger.event.data['search'] }}"
Folder: "{{ trigger.event.data['folder'] }}"
Sender: "{{ trigger.event.data['sender'] }}"
Date: "{{ trigger.event.data['date'] }}"
Subject: "{{ trigger.event.data['subject'] }}"
To: "{{ trigger.event.data['headers'].get('Delivered-To', ['n/a'])[0] }}"
Return-Path: "{{ trigger.event.data['headers'].get('Return-Path',['n/a'])[0] }}"
Received-first: "{{ trigger.event.data['headers'].get('Received',['n/a'])[0] }}"
Received-last: "{{ trigger.event.data['headers'].get('Received',['n/a'])[-1] }}"
