I’ve got a brand new installation on a raspberry pi 3 64 bit version.
I’m brand new too.
Flashed fine, but gets stuck in a loop trying to update on first boot.
Here’s the info though I don’t know how to look at it.
Preparing Home Assistant
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[07:35:19] INFO: Using udev information from host
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[07:35:19] INFO: Starting local supervisor watchdog...
[fix-attrs.d] done.
[07:35:25] INFO: Using udev information from host
[cont-init.d] done.
[services.d] done.
[07:35:25] INFO: Starting local supervisor watchdog...
22-03-11 07:35:29 INFO (MainThread) [__main__] Initializing Supervisor setup
22-03-11 07:35:29 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
22-03-11 07:35:29 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-03-11 07:35:29 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3-64
22-03-11 07:35:29 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/aarch64-hassio-supervisor with version 2022.05.1
22-03-11 07:35:29 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
22-03-11 07:35:30 WARNING (SyncWorker_0) [supervisor.docker.interface] Can't find homeassistant/aarch64-hassio-supervisor for cleanup
22-03-11 07:35:30 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-03-11 07:35:30 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-11 07:35:30 INFO (MainThread) [__main__] Setting up Supervisor
22-03-11 07:35:32 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-03-11 07:35:32 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-03-11 07:35:32 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-03-11 07:35:32 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-03-11 07:35:33 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-03-11 07:35:33 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-03-11 07:35:33 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-03-11 07:35:34 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-03-11 07:35:34 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-03-11 07:35:34 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-03-11 07:35:34 INFO (MainThread) [supervisor.host.info] Updating local host information
22-03-11 07:35:34 INFO (MainThread) [supervisor.host.services] Updating service information
22-03-11 07:35:34 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-03-11 07:35:34 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-03-11 07:35:34 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 07:35:34 INFO (MainThread) [__main__] Initializing Supervisor setup
22-03-11 07:35:35 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-03-11 15:35:35 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi3-64
22-03-11 15:35:35 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/aarch64-hassio-supervisor with version 2022.05.1
22-03-11 15:35:35 WARNING (SyncWorker_0) [supervisor.docker.interface] Can't find homeassistant/aarch64-hassio-supervisor for cleanup
22-03-11 15:35:35 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-03-11 15:35:35 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-11 15:35:35 INFO (MainThread) [__main__] Setting up Supervisor
22-03-11 07:35:36 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 15:35:36 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-03-11 15:35:36 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-03-11 15:35:36 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-03-11 15:35:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-03-11 15:35:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-03-11 15:35:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-03-11 07:35:37 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-03-11 15:35:37 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-03-11 15:35:38 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-03-11 15:35:38 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-03-11 15:35:38 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.resolve1
22-03-11 15:35:38 INFO (MainThread) [supervisor.host.info] Updating local host information
22-03-11 15:35:38 INFO (MainThread) [supervisor.host.services] Updating service information
22-03-11 15:35:38 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-03-11 15:35:38 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-03-11 15:35:38 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 15:35:38 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2022.05.0'>]
22-03-11 15:35:38 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.05.0
22-03-11 15:35:38 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-03-11 15:35:39 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-11 15:35:40 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.05.0 - 172.30.32.5
22-03-11 15:35:41 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
22-03-11 15:35:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
22-03-11 15:35:41 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
22-03-11 15:35:41 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-03-11 15:35:41 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.05.0
22-03-11 15:35:41 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-03-11 15:35:41 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_cli application
22-03-11 15:35:43 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1 - 172.30.32.3
22-03-11 15:35:43 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-03-11 15:35:43 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2022.05.0'>]
22-03-11 15:35:43 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0
22-03-11 15:35:44 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-03-11 15:35:44 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2022.05.0 - 172.30.32.5
22-03-11 15:35:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1
22-03-11 15:35:44 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
22-03-11 15:35:44 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
22-03-11 15:35:46 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0 - 172.30.32.4
22-03-11 15:35:46 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
22-03-11 15:35:46 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
22-03-11 15:35:46 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
22-03-11 15:35:46 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2022.04.1 - 172.30.32.3
22-03-11 15:35:46 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-03-11 15:35:47 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0
22-03-11 15:35:47 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-03-11 15:35:47 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_audio application
22-03-11 15:35:49 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0 - 172.30.32.6
22-03-11 15:35:49 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
22-03-11 15:35:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0
22-03-11 15:35:49 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-03-11 15:35:49 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2022.05.0 - 172.30.32.4
22-03-11 15:35:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2021.10.0
22-03-11 15:35:49 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_multicast application
22-03-11 15:35:51 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2022.02.0 - Host
22-03-11 15:35:51 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-03-11 15:35:54 WARNING (MainThread) [supervisor.utils.codenotary] rpc error: code = Unavailable desc = connection error: desc = "transport: authentication handshake failed: x509: certificate has expired or is not yet valid: current time 2022-03-11T07:35:53Z is before 2022-03-31T09:22:44Z"
22-03-11 15:35:54 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.TRUST - ContextType.SYSTEM / None
22-03-11 15:35:54 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_INTEGRITY - ContextType.SYSTEM / None
22-03-11 15:35:54 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
22-03-11 15:35:54 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
22-03-11 15:35:54 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
22-03-11 15:35:54 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
22-03-11 15:35:54 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning homeassistant application
22-03-11 15:35:54 INFO (SyncWorker_1) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi3-64-homeassistant
22-03-11 15:35:54 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi3-64-homeassistant found.
22-03-11 15:35:54 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
22-03-11 15:35:56 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
22-03-11 15:35:56 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 8.0 / BootSlot A
22-03-11 15:35:56 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
22-03-11 15:35:56 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
22-03-11 15:35:56 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
22-03-11 15:35:56 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': SSL certificate problem: certificate is not yet valid
22-03-11 15:35:56 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
22-03-11 15:35:56 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
22-03-11 15:35:56 ERROR (MainThread) [supervisor.store] Can't load data from repository core
22-03-11 15:35:56 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': SSL certificate problem: certificate is not yet valid
22-03-11 15:35:56 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
22-03-11 15:35:56 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / a0d7b954
22-03-11 15:35:56 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/hassio-addons/repository
22-03-11 15:35:56 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
stderr: 'Cloning into '/data/addons/git/5c53de3b'...
fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': SSL certificate problem: certificate is not yet valid
22-03-11 15:35:56 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
22-03-11 15:35:56 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / 5c53de3b
22-03-11 15:35:56 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/esphome/home-assistant-addon
22-03-11 15:35:56 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
22-03-11 15:35:56 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-03-11 15:35:56 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-03-11 15:35:56 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-03-11 15:35:56 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-03-11 15:35:56 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-03-11 15:35:56 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-03-11 15:35:56 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-03-11 15:35:57 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-11 15:35:57 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-03-11 15:35:57 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-03-11 15:35:57 INFO (MainThread) [__main__] Running Supervisor
22-03-11 15:35:57 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi3-64-homeassistant with version landingpage
22-03-11 15:35:57 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-03-11 15:35:57 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor.txt
22-03-11 15:35:57 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 8.0 / BootSlot A
22-03-11 15:35:57 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
22-03-11 15:35:57 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
22-03-11 15:35:57 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
22-03-11 15:35:57 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
22-03-11 15:35:57 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / 5c53de3b
22-03-11 15:35:57 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / 5c53de3b
22-03-11 15:35:57 ERROR (MainThread) [supervisor.store] Can't load data from repository https://github.com/esphome/home-assistant-addon
22-03-11 15:35:57 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
22-03-11 15:35:57 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
22-03-11 15:35:57 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
22-03-11 15:35:57 ERROR (MainThread) [supervisor.store] Can't load data from repository core
22-03-11 15:35:57 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
