My first attempt at Home Assistant. I followed the instructions and put the Raspberry PI OS for Home Assistant on a new SD card, inserted into PI and started it up.
I am unable to login to it via web page. When I connect the HDMI to a monitor I can see the attached screenshot. It keeps looping indefinitely with Bluetooth error.
I have the same error. I have the same RPI 3B. I am able to start and run HA from my laptop. The bluetooth error doesn’t seem to effect anything yet. I integrated three add-ons. I know two are working, the third I haven’t tried yet.
This error went away when I installed HA on a RPI4. I am not sure that was the difference tho. I also installed HA on a different LAN with a faster download speed and discoverable bluetooth entities.
@Erik101 Were you able to find a solution for this? I just for a RPi 3b for this and unable to proceed. Got it on facebook marketplace so return is not an option unfortunately.
I have the same issue on RPI 3b with the latest HA version Core
2024.12.3 and Supervisor 2024.11.4. Error message is: bluetooth hci0: Frame reassembly failed (-84). Any solutions ?
