Hi All,
I’m relatively new to HassOS. I’ve decided to play around with it on a spare Windows 10 pc. I’ve managed to run HassOS using VirtualBox. I can see the Home Assistant splash screen (dos) which also shows an IP address.
The issue is that I can’t log into HA using any of the methods that I’ve found online:
homeassistant.local:8123
ip:8123
I can see that my router has successfully assigned an IP to the HA instance and it matches with the one shown on the splash screen, but I’m not sure how to proceed.
Any suggestions?
