New install virtualbox SSL broken out of the box
Completely fresh installation. I can connect to HTTP just fine. But as soon as I try to open hass.io on HTTPS I get the following error in my browsers:
Chrome - ERR_SSL_PROTOCOL_ERROR
Firerox - SSL_ERROR_RX_RECORD_TOO_LONG
My home-assistant.log is empty. Also when I try to visit the webpage on HTTPS home-assistant.log remains empty.
My configuration.yaml:
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: *****
  longitude: *****
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Europe/Amsterdam
  # Customization file
  customize: !include customize.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Show the introduction message on startup.
introduction:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
http:
  base_url: *****.duckdns.org:8123
  ip_ban_enabled: True
  login_attempts_threshold: 5
#  ssl_certificate: /ssl/fullchain.pem
#  ssl_key: /ssl/privkey.pem
# Discover some devices automatically
discovery:
# Sensors
  # Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yaml
I’ve tried implementing DuckDNS and that fails miserably as well, as soon as uncomment the lines:
And restart Home Assistant server it’s dead with the following lines in home-assistant.log:
2019-04-24 16:46:39 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
  File "uvloop/sslproto.pyx", line 500, in uvloop.loop.SSLProtocol._on_handshake_complete
  File "uvloop/sslproto.pyx", line 484, in uvloop.loop.SSLProtocol._do_handshake
  File "/usr/local/lib/python3.7/ssl.py", line 763, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:1056)
2019-04-24 16:46:45 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2019-04-24 16:46:50 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2019-04-24 16:46:55 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2019-04-24 16:47:00 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
I have to remove the lines from the config file and reboot to get it working again. DuckDNS generated the certificates and they look fine to me. Altough the private key is probably password encrypted because it’s invalid according to openssl.
Now also tried Let’s Encrypt plugin and removed DuckDNS. Exactly the same errors.
Basically this:
Found the solution after hours of searching and trying various things.
Put this in the http config:
ssl_profile: intermediate
It don’t solve my problem. Looking for a fresh start or update… Good for you that it solves your problem!
