SSL Encryption with DuckDNS breaks hassio
The below code when used in the configuration.yaml file prevents Hassio web page from responding. The DuckDNS add-on worked without it.
http:
  base_url: https://my-domain.duckdns.org:8123
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
I also am using the correct domain in the yaml file.
Try removing https://
http:
  base_url: my-domain.duckdns.org:8123
if that doesn’t work drop the port as well.
Mine works configured like so:
base_url: mydomain.duckdns.org
I have port 443 forwarded to port 8123
No luck :frowning: thanks for the help though.
here is my log:
2018-11-09 11:16:00 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
  File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:841)
2018-11-09 11:16:01 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
  File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
2018-11-09 11:16:02 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 11:16:02 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 11:16:03 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 11:16:03 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 11:16:07 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 11:16:07 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 11:16:39 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 11:16:40 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 11:16:40 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 11:17:01 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 11:17:01 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 11:28:48 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 11:28:48 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 11:28:49 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 11:28:49 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 11:32:54 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 11:32:54 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 11:32:55 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 12:15:09 ERROR (MainThread) [homeassistant.components.updater] Got unexpected response: None
2018-11-09 12:17:16 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 12:17:16 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 13:20:08 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 13:20:08 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 13:20:09 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed
2018-11-09 13:20:09 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
2018-11-09 13:49:53 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason: HTTP_REQUEST
Where are you accessing ha from? Inside the same lan? Or from outside it?
I assume you have installed the certificates ? And is that address /ssl/fullchain.pem looks like an odd address.
Sorry, i didn’t realise i actually had to install ssl certificates. How can you do this?
You don’t. If you use the hassio ducDNS addon it should have done it for you.
This add-on includes support for Let’s Encrypt and will automatically create and renew your certificates. You will need to sign up for a Duck DNS account before using this add-on.
If i don’t add the code in the http: section it doesn’t say it is encrypted and shows a red unlocked lock in my browser, so i’m a bit confused as to what to do next.
Has this been resolved? It looks a lot like the trouble I’m having. DuckDNS addon reports okay in Log, but can’t access https address remotely. States “This site can’t provide a secure connection”. I can connect via http though
Hi Dave - did you solve this? I have the same issue
I’m also wondering that. I have the exact same issue…
Some one solve this? I have the same issue with http i can access but with https it says:
This site can’t provide a secure connectionMY-DOMAIN.duckdns.org sent an invalid response.
Try running Windows Network Diagnostics.
ERR_SSL_PROTOCOL_ERROR
I am having the same issue. Anyone??
I first tried using my existing domain name and getting my key from the Let’sEncrypt Add-on at the Hassio store.
When that failed to work, I preceeded to try the DuckDNS method since there seems like a lot more documentation on this process.
Both methods I get a positive confirmation that everything was successful and I get the certificate and key created in the Hassio directory: root/ssl/
I have tried these version of port-forwarding
8123 --> 8123 --> 192.168.1.205
443 --> 8123 --> 192.168.1.205
80 --> 8123 --> 192.168.1.205
I have the following lines in the configuration.yaml file
--http:
----base_url: mysite.duckdns.org:8123
----ssl_certificate: /ssl/fullchain.pem
----ssl_key: /ssl/privkey.pem
when I try to access Hassio via: https://mysite.duckdns.org I get “This site can’t provide a secure connection”
I have no issues accessing the site through http://mysite.duckdns.org
What am I doing wrong? Is there another step I am missing? I have tried all of these steps on a brand new setup of Hassio as well as my existing setup.
I have an indenting question for the http: section. When I look at everyone’s configuration.yaml file online, there is NO indent for the ‘http:’ and a 2 space indent for everything under it. If I use this indentation method, my frontend will fail to load once I add the ssl_certificate and ssl_key sections. If I indent the ‘http:’ 2 spaces and everything else 4 spaces, I have no issue. I have checked spacing and confirmed no tabs more times than I can count. What is the correct way to indent this section and could this be causing me the problem I am having?
Thanks for any help
Change the url you access to https://mysite.duckdns.org:port#, where port# = the external port forwarding address.
Thanks, I assume you are talking about the base_url, but either way I have tried every variation of the base_url and means of trying to access the url from a browser (with/without port, with/without http://, with/without https://)
As I mentioned at the bottom of my post, I think I have the incorrect indentation, but when I tried to do the correct indentation my Hassio UI fails to load.
All I can do is show you what worked for me : -
Mutt - I’m not sure where you live, but next time you are in Northern California, I’ll buy you as much beer as you can drink. THANKS for taking the time to post. I have spent 1.5 days working on this and trying to get the Base SSL methodology to work. I see lots of others running into the same issue I had, but no one seems to have a solution/fix.
Funny thing is that I couldn’t get it to work with my DuckDNS.org domain, but really I wanted to use my own domain name and I was successful at that. Your instructions were first rate. I only wish the group at Home Assistant would hire you to write all of their documentation. I spend so much time trying to decipher instructions and so little time enjoying my Hassio.
I put a twist on my setup since I have 2 Hassio machines running (Home and Barn).
I used your instructions exactly for my ‘Main’ Home Hassio Machine, and followed your instructions for the 2nd Hassio with the exception that I changed the Port at the bottom of the NGINX setup to a different Port#. Now I can access my Main Hassio using https://mydomain.com and my second Hassio using https://mydomain.com:xxxxx
Again - It’s been a painful learning experience, but I appreciate your help!! Hopefully others find your thread and benefit from it.
Hahaha.! I spent over a week. :roll_eyes: I notice that some other instructions in the thread were VERY different to mine, so people’s mileages vary greatly. Note that some very clever guys helped put the pieces together on that thread (liking that will raise its ranking) I merely benefited from their help AND tried a LOT of permutations.
I would NOT have done what you did with the port. But I suppose you had to if going through the same modem/router. So no choice.
I can’t find any ‘donate to HA’ facilities (someone correct me if they can) but the next best thing is to contribute to frenk (via most of the hassio add ons.
Glad it helped you
