New install using the RPI imager onto a RPI3, model B. The observer webpage reports everything is connected and healthy. The logs though say that there is an error installing home assistant. Repeated error messages:
[supervisor.docker.interface] Can’t install ghcr.io/home-assistant/raspberrypi3-64-homeassistant:2024.1.2: 500 Server Error for http+docker://localhost/v1.43/images/create?tag=2024.1.2&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi3-64-homeassistant&platform=linux%2Farm64: Internal Server Error (“Get Deleted because I can’t include a second webpage link as a new user: context deadline exceeded”)
I managed to resolve this by editing the home assistant dns, using the following steps:
Connect to the RPI locally using a keyboard and display. Make sure youre network is connected.
At the screen where it says >ha type login
-That should then give you a #
Type ping 8.8.8.8 to confirm that you do have a network connection
Type vi /etc/resolv.conf
This brings up the dns settings in an editable format
You might see your routers IP address there. Mine was 192.168.1.254
Edit that to be 8.8.8.8 (Googles dns server)
Press the esc key twice
Type :wq
That will save and close the file.
You can type login again to go back to the home assistant screen
Just wait a few minutes, home assistant should be able to then update and proceed with the setup. You can monitor the progress at http://homeassistant.local:8123/
My installation completed sucessfully and home assistant is now running on my raspberry pi 3
