New Installation - gets no IP
Hey there Home Assistant Community
I’m trying my first steps with home assistant but it doesn’t work as desired.
I’m using a RPi 3b and I flashed the recent image using Etcher.
I connected it to my router and nothing happens. LEDs are flashing but that’s it.
So I got suspicious and connected to my monitor.
It seems like everything is running but it’s not getting any IP address from my router.
The router doesn’t even recognize it as a new device.
I have no mac filtering or additional security.
If I type net info eth0 it outputs:
Connected: true
Enabled:true
Interface: eth0
Ipv4:
Adress[]
Gateway: null
Method: disabled
Nameservers: []
Any idea how to fix this?
Thanks a lot!
Simple things first, have you tried another network cable?
Yes I have.
And another Port on the Router.
I tried setting a static IP using nmcli but still no change.
Any solution to this?
I have same problem after a fresh installation.
When I connect cable to my my laptop interface gets an ip address but HA does not.
