Hi All, was using home assistant OS in a VM housed on my NAS previously for 2 years.
I am trying to migrate over to OpenWRT as I have more computing power (x86) on it. I have successfully gotten docker install on OpenWRT and was confused with the large list of official images that are available on hub.docker.com
I would like to understand more if there are any differences between those that are listed an if the architecture actually matters in this case. Naturally, which of these should I use?
I am getting the following error. I found a similar error online regarding the specification of block IO weight, I specified 500 and 1000 and still unable to start the container.
Containers: start hass...code:400 failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error setting cgroup config for procHooks process: openat2 /sys/fs/cgroup/docker/d482867fe08504edd1df3e050e6b0c88625f13ea254053d97a67b9a19cf082f0/io.weight: no such file or directory: unknown
