New Insteon version for beta testing - (Do not use since this is now in 0.111 and higher)
Got merged yesterday.
Sorry about that one guys and thanks to the multiple people who identified the code issue and even submitted PRs to help. Appreciate that.
FYI, the actual fix did not get merged into the dev branch until today. Not sure when it will hit production but looks like it will be in 2021.7.3.
2021.7.3 is out and the fix is working. thanks @teharris1 and all for the integration, our homes are smarter because of you :slight_smile:
I second that thought! SO happy to have this kind of support in this community!
Hello everyone. It has been a while since anything else on here. I am just trying HA for the first time and I seem to be having issues with Insteon. I can not seem to find anything recent about this. Anyone have any ideas? This is what I have running “core-2021.9.7” If that helps.
are you facing any issues? I just upgraded from 9.7 to 10.xb and insteon working perfectly for long time now … it is even way faster than Inston own app.
simply add it from integrations page
I just upgraded to that as well. It will not let me even log into my insteon hub. (Using the Hub 2) I just keep getting a “Failed to connect” error. I have tried both the local IP and the Public IP. It seems pretty straight forward but it just won’t connect. :slightly_frowning_face:
are you using the username and password printed on the bottom of the hub?
Anybody else experiencing issues with core-2021.10.5.
When I upgrade … modem refuse connection !!
There have not been any changes to the Insteon integration in a few months. What do the logs say?
hey @teharris1 , sorry for the late reply … I did not save the logs … it was something along modem refused connection in the integration page … I downgraded to 10.4 then, I upgraded to 10.6 today and all is working normal. might have been an anomaly …
thanks for all your support
Sorry for revive this but I’m having issues with my KPL’s and the Insteon hub 2245.
I recently changed my IM from USB stick to the “traditional” 2245.
The issue is:
When I add the KPL through the Insteon app works from the app itself, appears on HA and HA serves as controller with any issue.
HA can’t listen to the changes made on the KPL so is not acting as responder.
So I went to services and trigger a Insteon add all link as responder groups 0 to 5 activating first the KPL and then trigger the service. This work and HA listen changes.
But when I restarted HA the entire KPL shows as unavailable.
The workaround I found was adding a device override with the same cat and sub cat that HA was showing (0x02 0x2c) and then works.
But one of my KPL with this “fix” shows as unavailable since last night so I don’t know what is happening here. My Insteon App show the broken KPL normally and can control it.
There’s anybody with this issue?
