I would like to integrate a older system that I have on home but I need help to go forward.
The system has a web interface and I achieved to understant how it works (I think).
It only accept HTTP GET requests.
1st - I need to autenticate and save the cookie (“curl -d” seams to do the work). The following requests are made with “curl -c” to read the cookie.
2nd - I do not have status by device, just all devices, with names, groups, etc, and it is the only way to get device status, because after device change I just receive “code 200” and not the device status.
I think it should be called periodicaly (like 5 seconds interval)
3rd - To change a device value I just do a GET with device CODE and VALUE.
Do you know any integration identical, to a noob programmer (me) try to adapt?
If not, should I use command line or do I have better solution?
Thank you for your support.
-------- Resquests and responses -------------------
Autentication
curl -d GET "http://192.168.1.99:8888/logas?value=4a8352b6a6ecdb4106b2439aa9e8638a0cdbb16ff3568616f4ccb788d92538fe&value1=4701754001718"
{"Hello":[{"Login":"OK"}]}
Device Status
curl -b GET "http://192.168.1.99:8888/json?devices"
{"devices":{"infrared":[],"all":[{"dst":2,"cod":"MDO6","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":32,"name":"Sancas"},{"dst":1,"cod":"MDO7","status":"S","value":0,"floor":2,"dt":1,"control":2,"room":32,"name":"Tecto Coz"},{"dst":1,"cod":"MDO9","status":"S","value":0,"floor":2,"dt":1,"control":2,"room":32,"name":"Tecto TV"},{"dst":3,"cod":"MDO86","status":"S","value":0,"floor":2,"dt":2,"control":2,"room":32,"name":"Sala Esq."},{"dst":3,"cod":"MDO87","status":"S","value":0,"floor":2,"dt":2,"control":2,"room":32,"name":"Sala Dir."},{"dst":3,"cod":"MDO89","status":"S","value":0,"floor":2,"dt":2,"control":2,"room":2,"name":"Janela"},{"dst":3,"cod":"MDO90","status":"S","value":0,"floor":2,"dt":2,"control":2,"room":2,"name":"Porta"},{"dst":2,"cod":"MDO168","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Alpendre Sala"},{"dst":2,"cod":"MDO169","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":5,"name":"Entrada"},{"dst":2,"cod":"MDO170","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":5,"name":"Acesso Sala"},{"dst":2,"cod":"MDO172","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":5,"name":"Escadas"},{"dst":2,"cod":"MDO174","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Apendre entrada"},{"dst":2,"cod":"MDO175","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Jardim (Pedonal)"},{"dst":2,"cod":"MDO176","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Jardim (Auto)"},{"dst":8,"cod":"MDO177","status":"S","value":0,"floor":2,"dt":4,"control":1,"room":25,"name":"Recirculação"},{"dst":2,"cod":"MDO180","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Muro poente"},{"dst":8,"cod":"MDO181","status":"S","value":100,"floor":2,"dt":4,"control":1,"room":25,"name":"Termoacumulador"},{"dst":2,"cod":"MDO183","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":2,"name":"Cozinha"},{"dst":2,"cod":"MDO184","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":37,"name":"Lavandaria"},{"dst":2,"cod":"MDO185","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Exterior - Cozinha"},{"dst":2,"cod":"MDO186","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":37,"name":"Hall - Lavandaria"},{"dst":2,"cod":"MDO187","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":7,"name":"WC"},{"dst":2,"cod":"MDO188","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":36,"name":"Escritório"},{"dst":2,"cod":"MDO189","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":36,"name":"Escritório - desk"},{"dst":8,"cod":"MDO190","status":"S","value":100,"floor":2,"dt":4,"control":1,"room":7,"name":"Extractor"},{"dst":2,"cod":"MDO193","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Varanda"},{"dst":8,"cod":"MDO194","status":"S","value":0,"floor":1,"dt":4,"control":1,"room":40,"name":"Tomadas Sótão"},{"dst":2,"cod":"MDO195","status":"S","value":0,"floor":1,"dt":1,"control":1,"room":42,"name":"Roupeiro"},{"dst":2,"cod":"MDO196","status":"S","value":0,"floor":1,"dt":1,"control":1,"room":42,"name":"Ilum. Tecto"},{"dst":2,"cod":"MDO197","status":"S","value":0,"floor":1,"dt":1,"control":1,"room":43,"name":"Ilum. Vestiário"},{"dst":2,"cod":"MDO198","status":"S","value":0,"floor":1,"dt":1,"control":1,"room":40,"name":"Ilum. Corredor"}],"equipments":[{"dst":8,"cod":"MDO177","status":"S","value":0,"floor":2,"dt":4,"control":1,"room":25,"name":"Recirculação"},{"dst":8,"cod":"MDO181","status":"S","value":100,"floor":2,"dt":4,"control":1,"room":25,"name":"Termoacumulador"},{"dst":8,"cod":"MDO190","status":"S","value":100,"floor":2,"dt":4,"control":1,"room":7,"name":"Extractor"},{"dst":8,"cod":"MDO194","status":"S","value":0,"floor":1,"dt":4,"control":1,"room":40,"name":"Tomadas Sótão"}],"climatization":[{"dst":7,"cod":"MDO2474","status":"S","value":76,"floor":2,"dt":19,"control":2,"room":44,"name":"Teste Analogico"}],"blinds":[{"dst":3,"cod":"MDO86","status":"S","value":0,"floor":2,"dt":2,"control":2,"room":32,"name":"Sala Esq."},{"dst":3,"cod":"MDO87","status":"S","value":0,"floor":2,"dt":2,"control":2,"room":32,"name":"Sala Dir."},{"dst":3,"cod":"MDO89","status":"S","value":0,"floor":2,"dt":2,"control":2,"room":2,"name":"Janela"},{"dst":3,"cod":"MDO90","status":"S","value":0,"floor":2,"dt":2,"control":2,"room":2,"name":"Porta"}],"others":[],"sensors":[],"curtains":[],"illumination":[{"dst":2,"cod":"MDO6","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":32,"name":"Sancas"},{"dst":1,"cod":"MDO7","status":"S","value":0,"floor":2,"dt":1,"control":2,"room":32,"name":"Tecto Coz"},{"dst":1,"cod":"MDO9","status":"S","value":0,"floor":2,"dt":1,"control":2,"room":32,"name":"Tecto TV"},{"dst":2,"cod":"MDO168","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Alpendre Sala"},{"dst":2,"cod":"MDO169","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":5,"name":"Entrada"},{"dst":2,"cod":"MDO170","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":5,"name":"Acesso Sala"},{"dst":2,"cod":"MDO172","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":5,"name":"Escadas"},{"dst":2,"cod":"MDO174","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Apendre entrada"},{"dst":2,"cod":"MDO175","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Jardim (Pedonal)"},{"dst":2,"cod":"MDO176","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Jardim (Auto)"},{"dst":2,"cod":"MDO180","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Muro poente"},{"dst":2,"cod":"MDO183","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":2,"name":"Cozinha"},{"dst":2,"cod":"MDO184","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":37,"name":"Lavandaria"},{"dst":2,"cod":"MDO185","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Exterior - Cozinha"},{"dst":2,"cod":"MDO186","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":37,"name":"Hall - Lavandaria"},{"dst":2,"cod":"MDO187","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":7,"name":"WC"},{"dst":2,"cod":"MDO188","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":36,"name":"Escritório"},{"dst":2,"cod":"MDO189","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":36,"name":"Escritório - desk"},{"dst":2,"cod":"MDO193","status":"S","value":0,"floor":2,"dt":1,"control":1,"room":25,"name":"Varanda"},{"dst":2,"cod":"MDO195","status":"S","value":0,"floor":1,"dt":1,"control":1,"room":42,"name":"Roupeiro"},{"dst":2,"cod":"MDO196","status":"S","value":0,"floor":1,"dt":1,"control":1,"room":42,"name":"Ilum. Tecto"},{"dst":2,"cod":"MDO197","status":"S","value":0,"floor":1,"dt":1,"control":1,"room":43,"name":"Ilum. Vestiário"},{"dst":2,"cod":"MDO198","status":"S","value":0,"floor":1,"dt":1,"control":1,"room":40,"name":"Ilum. Corredor"}],"electricvalves":[{"dst":13,"cod":"MDO178","status":"S","value":0,"floor":2,"dt":6,"control":1,"room":25,"name":"Rega Trás - Zona1"},{"dst":13,"cod":"MDO179","status":"S","value":0,"floor":2,"dt":6,"control":1,"room":25,"name":"Rega Trás - Zona2"},{"dst":13,"cod":"MDO1809","status":"S","value":0,"floor":2,"dt":6,"control":1,"room":36,"name":"output virtual anoitecer"},{"dst":13,"cod":"MDO2475","status":"S","value":100,"floor":2,"dt":6,"control":1,"room":44,"name":"Fim de Semana"},{"dst":13,"cod":"MDO2476","status":"S","value":0,"floor":2,"dt":6,"control":1,"room":44,"name":"Estores Bloqueados"},{"dst":13,"cod":"MDO2477","status":"S","value":0,"floor":2,"dt":6,"control":1,"room":44,"name":"flag AlarmeParcial MD"},{"dst":13,"cod":"MDO2478","status":"S","value":0,"floor":2,"dt":6,"control":1,"room":44,"name":"flag AlarmeTotal MD"}]},"subtypes":{"items":[{"id":1,"type":1,"name":"Iluminação Dimmer"},{"id":2,"type":1,"name":"Iluminação On/Off"},{"id":3,"type":2,"name":"Estore"},{"id":7,"type":19,"name":"Ventilação"},{"id":8,"type":4,"name":"Saida On/Off"},{"id":13,"type":6,"name":"Eletroválvula"},{"id":18,"type":8,"name":"Interruptor Normal"},{"id":19,"type":8,"name":"Interruptor Dimmer"},{"id":24,"type":17,"name":"Sensor Presença"},{"id":27,"type":10,"name":"Sensor Incêndio/Falta energia"}]},"types":{"items":[{"id":1,"name":"Iluminação"},{"id":2,"name":"Estores/Cortinas"},{"id":4,"name":"Tomadas"},{"id":6,"name":"Eletroválvulas"},{"id":8,"name":"Interruptor/Botão"},{"id":10,"name":"Sensores Técnicos"},{"id":17,"name":"Sensores Presença/Intrusão"},{"id":19,"name":"Climatização"}]},"resp":200,"rooms":{"items":[{"floor":2,"id":2,"multimedia":1,"name":"Cozinha "},{"floor":2,"id":5,"name":"Hall entrada"},{"floor":2,"id":7,"name":"WC Serviço"},{"floor":2,"id":25,"name":"Exterior"},{"floor":2,"id":32,"name":"Sala de estar"},{"floor":2,"id":36,"name":"Escritório"},{"floor":2,"id":37,"name":"Lavandaria"},{"floor":1,"id":40,"name":"Corredor"},{"floor":1,"id":42,"name":"Q. Camila"},{"floor":1,"id":43,"name":"Vestiário"},{"floor":2,"id":44,"name":"Quadro Alarme"}]},"floors":{"items":[{"id":1,"name":"Piso+1"},{"id":2,"name":"Piso-0"}]}}
Turn OFF device
curl -b GET "htp://192.168.1.99:8888/control?device&cod=MDO6&value=0"
{"resp":200}
