What does this integration take care of, and should we really set it? We always are warned not to, so automatic port mapping seems somewhat counter standard security measures…
never heard of a traffic sensor btw, so would know what to fill in there?
I have several ports forwarded on my router, which is also not as safe as it should be. can we use this integration to set these port forwarding? and are they maybe safer this way?
hope anyone has tested already, and would care to share experience. thx
I also want to ignore it, tried - upnp but it doesn’t work. I keep getting message at startup thst something new is discovered and have to click dismiss.
I also got a new discovery component in this version (my d-link router).
When I look at the sensors that was automatically created all the data is 0.
How can I fix it ?
Sure.
If you really need it, you shouldn’t disable it on the router. The thing is, it is one of the bigger red flags in network security risks, enabling Upnp. So, you got to have a very good reason to enable it…
I used to believe to need it for my network devices to see each other, but since I’ve disabled it, nothing changed in my home functionality. Feels safer…
Of course, ymmv.
This integration made my pfSense router pretty unhappy. The router box would go completely unresponsive every 12-36 hours during the short time I had this integration enabled.
i also need some reviews about this facility , is it safe to use it ?
it automatically shows in HA but all the router values are 0,
how to successfully configure it ?
