The new Android mobile interface is horrible. with AC control all you have is temperature up and down unless you go into sub menu to turn off or change mode.
The other problem is using IR blaster with the old app you could send the same command multiple times, since some times the IR blaster’s command doesn’t register with AC. Now with the new interface you can’t send multiple commands by pressing the same button because it’s a drop down.
Anyone else experiencing the same issue?
