s6-rc: info: service base-addon-banner: starting
[06:24:25] INFO: Starting: mqtt-s7-connector
Add-on: MQTT Siemens S7 Connector
MQTT Siemens S7 connector to integrate Siemens PLC’s with Home Assistant
Add-on version: 1.0.8
You are running the latest version of this add-on.
System: Home Assistant OS 15.2 (amd64 / generic-x86-64)
Home Assistant Core: 2025.5.3
Home Assistant Supervisor: 2025.05.3
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
Log level is set to TRACE
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init: starting
[06:24:26] INFO: Copying example config files…
s6-rc: info: service init successfully started
s6-rc: info: service legacy-services: starting
[email protected] start
node index.js --addonversion 1.0.8 --config /config/config.yaml --loglevel=0
s6-rc: info: service legacy-services successfully started
INIT ## log level is set to: 0
[63225,570608566] Initiate Called - Connecting to PLC with address and parameters:
[63225,570731861] { port: 102, host: ‘172.16.10.186’, rack: 0, slot: 1 }
[63225,571336946 172.16.10.186 S1] Connection cleanup is happening
[63225,572470980 172.16.10.186 S1] Attempting to connect to host…
[63225,580852236 172.16.10.186 S1] TCP Connection Established to 172.16.10.186 on port 102
[63225,580971623 172.16.10.186 S1] Will attempt ISO-on-TCP connection
[63225,581278025 172.16.10.186 S1] Using rack [0] and slot [1]
[63225,590100983 172.16.10.186 S1] ISO-on-TCP Connection Confirm Packet Received
[63225,634809940 172.16.10.186 S1] Received PDU Response - Proceeding with PDU 240 and 3 max parallel connections.
PLC Connected
2025-6-11 6:24:31 ## ERROR ## Connection Timeout
/usr/src/mqtt-s7-connector/service_functions.js:57
throw new Error(msg);
Error: Connection Timeout
at Object.error (/usr/src/mqtt-s7-connector/service_functions.js:57:9)
at Timeout._onTimeout (/usr/src/mqtt-s7-connector/index.js:85:8)
at listOnTimeout (node:internal/timers:614:17)
at process.processTimers (node:internal/timers:549:7)
Node.js v23.2.0
[06:24:31] INFO: Service mqtt-s7-connector exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service init: stopping
s6-rc: info: service mqtt-s7-connector: stopping
s6-rc: info: service mqtt-s7-connector successfully stopped
s6-rc: info: service init successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
WHERE CAN THE PROBLEM BE? It is normally connected via RED-NODE and works. I would like to switch to S7 connector for simplicity
