Does anyone have a complete list of all the sensors from the new Nest integration? I’d like to see what I have to fix or remove before I try it. Once you switch to Google Assistant, you can’t use the Works with Nest program anymore.
I’d be interested in this too - I’m still hanging on to my old Nest account.
The only sensors that I have are Temperature and Humidity.
I have Camera (Nest Hello) and Climate (Thermostat) control.
Too see what is available, look into Traits.
Currently, Security devices aren’t available (such as Yale Nest Lock).
I am using the latest Nest integration. It works fine as it can detect all thermometers in my home.
I’m going to wait until they get more stuff, like the smoke detectors added before I switch.
Am I able to use new and old Nest integrations at the same time?
Currently having smoke detectors with old Nest accout, can i use new example for doorbell cameras only?
I don’t think so. When Google announced the Works With Nest shutdown, they did say you could migrate to the Google Assistant and I believe it was one way only. Once converted, you couldn’t use the Works With Nest any longer.
You could probably open a different account for your doorbell and cameras You’d just need another email address.
