New Phillips powered by wiz devices not being detected by integration
I switched the last few Hue Devices I had over to the new Phillips bulbs “powered by” Wiz. Found them for a very cheap price. I have some of the old Wiz bulbs in use that are all working great in home assistant with the Wiz Integration.
For the new Phillips versions you have to use the new Wiz2 app on your phone where they are all detected just fine. However the integration in HA will not detect them. They are on a separate subnet from HA, but I have routes in my firewall that integrate all my subnets. My Home assistant server is on the LAN Subnet that they all connect to. If I auto detect or manually input the IP, neither will work.
When i enter the IP it determines it is a bulb but pops up the notification that it cant be setup by the WIZ integration.
I am guessing the current integration isn’t going to work with these bulbs. I have seen other users have gotten them to work in HA.
