pleased to announce the release version 1.0.0 or our new plugin Custom-attributes, that allows the user to control which attributes are displayed in the attributes dropdown on the more-info cards.
install as custom repo in HACS:
You can filter attributes that are shown, or unfilter attributes that HA filters by default.
@elchininet has been finetuning my suggestions, and has done most if not all of the coding, so kudos to him are in order!
If have been trying to keep custom-ui alive for years now, but the time has come to slowly say goodbye to that powerful plugin (it still is), and create more modern plugins to do some of its tasks separately.
Please checkin at the repo of Custom-attributes, have a look at its options and examples, and customize those attributes to your liking.
Want to take out all attributes on a light? no problem. There’s a powerful all
filter.
filter_attributes:
by_domain:
light:
- all
Want to see the device_class
on domain binary_sensor
(hidden by default)? go ahead.
unfilter_attributes:
by_domain:
# filtered by Home Assistant by default
binary_sensor:
- device_class
You can filter and unfilter by_domain
, by_glob
, by_entity_id,
and by_device_class
You could even hide all attributes everywhere by setting:
filter_attributes:
by_glob:
- all
The filter attributes works on all more-info cards, even when invoked from the developer-tools/state
Currently this is what I am using myself, and it cleans up the cards just perfectly:
# Custom attributes configuration settings #
# use a config per Dashboard, and add it to the root of the yaml file like #
# # title: Your Dashboard title # #
# # button_card_templates: !include_dir_merge_named ../button_card_templates # #
# # decluttering_templates: !include_dir_named ../decluttering_templates # #
# # kiosk_mode: !include ../kiosk-mode/kiosk-mode.yaml # #
# # custom_attributes: !include ../custom_attributes/custom_attributes.yaml # #
# # views: # #
# # - !include view_home.yaml # #
# # - !include view_number_two # #
# # - etc # #
# use the available 'debug' paramater if a filter does not work and you need to report
# malfunctioning to the issue tracker.
debug: true
# Unfilter #
by_domain:
binary_sensor:
- device_class
- device_class
# filtered by User in the filter_attributes
by_glob:
'device_tracker.google*':
- ip
- mac
- ap_mac
# Filter #
filter_attributes:
by_glob:
- icon_color
- id
# first filter 'all' in glob, then unfilter only what user needs in the unfilter section
- all
'sensor.ha_*_version':
- all
'sensor.buienradar_*':
- Stationname
'sensor.*_actueel': &meter # use a yaml anchor to easily c&p repetitive attributes
- meter_type
- meter_type_name
'sensor.*_totaal': *meter
'sensor.*_amperage': *meter
'sensor.*_voltage': *meter
'sensor.*_battery_state':
- templates
by_device_class:
enum:
- options
by_domain:
binary_sensor:
- hysteresis
light:
- all
siren:
- available_tones
by_entity_id:
sensor.cpu_speed:
- brand
- arch
group.media_players_device_trackers:
- all
group.hub_device_trackers:
- all
thanks for checkin in!
