New Request: ROTH Touchline - Underfloor Heating System
Operation mode isn’t working, Any chance for an update?
I’ve got this ROTH Touchline to work in HA, but it seems the thermostat entities and the actual physical thermostats are being randomly mixed up on every restart of HA. Example: Physical Thermostat #1 is first assigned to enitity_id “climate.nn”, while Physical Thermostat #2 is assigned to entity_id “climate.nn_2”. After reboot of HA it is opposit: Physical Thermostat #1 = climate.nn_2 and Physical Thermostat #1 = climate.nn. This makes the ROTH component totaly useless as I have to reassign thermostats to correct entities after every reboot. Is anyone else experiencing this as well?
Any feedback appreciated.
Thanks!
I also experience exactly the same problem with the entities on reboot.
I’ve two Roth Touchlines in the house - old type with LAN (unknown FW). One sertup as master and the other as slave. Initially i tried to establish contact to both using the official Roth app. But never got a connection to the second one. It simply couldn’t be found ?? I can ‘see it’ and ping it, but the app refuses to find it. So the master sensors 5 thermostat entities are named in the app and transferred to HA with name. The other 5 entities came in to HA without names (off course) and are ‘friendly named’ in customize.yaml
climate.nn:
  friendly_name: Badeværelse gæst
climate.nn_3:
  friendly_name: Alrum
climate.nn_2:
  friendly_name: Gang
climate.nn_4:
  friendly_name: Bryggers
climate.nn_5:
  friendly_name: Rasmus værelse
On every HA reboot the slave entities are shuffled and hence are useless… :roll_eyes:
Two reboots gives this shuffle for the five entities:
Alrum: Original: nn_3 first reboot:nn_4 second reboot:nn
Rasmus: Original: nn_5 first reboot:nn second reboot:nn_2
Gang: Original: nn_2 first reboot:nn_3 second reboot:nn_5
Badevær. Original: nn first reboot:nn_2 second reboot:nn_4
Bryggers: Original: nn_4 first reboot:nn_5 second reboot:nn_3
Alrum name equals sensor with nn_4 values after first reboot. After second reboot it changes again to the sensor which originally had nn values and so on.
Can’t the ‘friendly named’ slave entities be locked to the physical sensors in some way ?
It works perfectly with found and named sensors from the Roth app.
Any feedback appreciated as well.
Thank you in advance
Hi
I try to setup the Roth Touchline.
I can see in the log when I change the set point to e.g. 7d.g. but this is not send back to the thermostat. …
2019-03-20 09:46:53 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=climate.n_n, new_state=<state climate.n_n=unknown; friendly_name=Temp 01 - test, max_temp=35, supported_features=1, min_temp=7, current_temperature=23.1, temperature=9.0 @ 2019-03-20T10:45:07.346896+01:00>, old_state=<state climate.n_n=unknown; friendly_name=Temp 01 - test, max_temp=35, supported_features=1, min_temp=7, current_temperature=23.1, temperature=32.5 @ 2019-03-20T10:45:07.346896+01:00>>
hmm. it works. but with a delay of … 2 min ??
can I adjust the sensitivity ?
climate:
scan_interval: 10 do not solve my issue
Attached to this post is a link to a new version of the “climate.py” component for Roth Touchline, including the ability to set the operation mode via presets.
I made this new version, because I use it myself (I also made an older version, from before HA was updated with a new climate architecture)
The component is compatible with version 0.96.5.
I’ll see if I have the time to make a PR and go through all the hoops that awaits …
Remember to make a backup of the current “climate.py” if you find the new version worse than the old.
Zipped climate.py on my server (cm3.dk)
Thank you for your efforts to improve this integration. Have tested it for a while and it works great! Will be good if this improved version would have been added to the official HA integration as well.
Hi, try this in your climate platform:
http://192.168.225.51
I dont know why this is NOT documented, but i got 6 devices out of 10 that i got running in my Roth system.
Do you know why i dont got all of them?
I got this error now:
[homeassistant.components.climate] touchline: Error on device update!
not well-formed (invalid token)
Hi guys, i use the climate platform in Hassio, i got 10 Roth display, i only see 6 of them in Home-assistant.
I got this error in log:
2019-10-08 21:54:33 ERROR (MainThread) [homeassistant.components.climate] touchline: Error on device update!
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 292, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 441, in async_device_update
    await self.hass.async_add_executor_job(self.update)
  File "/usr/src/homeassistant/homeassistant/components/touchline/climate.py", line 52, in update
    self.unit.update()
  File "/usr/local/lib/python3.7/site-packages/pytouchline/__init__.py", line 60, in update
    response = self._request_and_receive_xml(request)
  File "/usr/local/lib/python3.7/site-packages/pytouchline/__init__.py", line 128, in _request_and_receive_xml
    return xml(content)
  File "/usr/local/lib/python3.7/xml/etree/ElementTree.py", line 1315, in XML
    parser.feed(text)
  File "<string>", line None
xml.etree.ElementTree.ParseError: not well-formed (invalid token): line 1, column 186
My climate platform is:
  - platform: touchline
    host: http://192.168.1.51
Can someone give me ideas how to fix this?
@pilehave
Did your climate.py solve the delay issue ?
I exchanged the climate.py in /srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/touchline/
Dit I miss a config issue ?
people addresed issue after 6 sesnsors; is this also solved in your version ?
thx.
Hi @janushansen
I still got this issue with more than 7 sensors. (i got 10) i started with only 6 sensors.
Meaby i should try to change the climate.py to solve this!, do you know @pilehave what version i should use of climate.py - meaby your latest one?
Now i got 7 sensors, but i am running hassio, do you know a fix?
Hi @pilehave did you forked the touchline project, so we can update in next realese of hassio?
Just installed this component.
A few things I’ve encountered.
Adding names to each thermostat in the app duplicates them in hass. I suddently get
bathroom, bathroom_2, bedroom, bedroom_2 and so on.
I’m also missing a few thermostats. I have two units for each floor and the thermostats are mixed, should probably be prefixed with unit id, name or whatever.
Did you write your thermostat names with “æøå” ?
Nope, no special characters.
Try name all the termostat first, and delete info in conf.yaml and then retry, is it still duplicate?
I got mine fixed after naming them properly.
Would you be able to port this to homebridge?
Really late reply here, been too busy :confused:
I tried again tonight but i still get duplicates of the one controller, they are true duplicates as in all the values are the same, second is suffixed with _2. I have two controllers, they are not connected to each other so I guess they are both “master”. Could this be causing the issue?
Got it figured out now. Units have to be master/slave because of the way this implementation works.
