New sensor / integration without restart?
Hello everyone,
while I pointlessly used to always restart Home Assistant after adding automations, scripts, etc., I eventually realized I could do this via settings > server > reload automations (or similar, my options are in German).
Is there something similar for new integrations or sensors one added via .yaml file? For example, I just added
alarm_control_panel:
  - platform: manual
    code: 6677
    code_arm_required: true
I can test whether this is valid via test configuration. It seems to be. Is there some way to load this without restarting Home Assistant that I have missed?
When testing new things, I usually go with the bare minimum (seen in the example above), then, when it works, fine-tune my configuration (in this case, add things such as arming_time, delay_time, etc.). This currently requires me to restart Home Assistant multiple times.
This isn’t a big deal. I have ansible on my home server and set an alias so that I just run hass docker restart hass, which will restart the docker container on the remote server. It works fine and only takes about a minute. However, doing this multiple times in a row is still somewhat “annoying”. I know, it is a minor thing, but perhaps there is a solution for this and I’d hate to go through this if there wasn’t a need for it.
To my understand, it ought to be possible, as automations and scripts can be reloaded without any issues without the need for restarting Home Assistant, so I just assume that it might work for other things as well…?
Thank you for your help.
No.
