New server control panel?
I read in the 0.97 Hassio update changes, that there is supposedly a new server control panel which splits out the core config options to this new panel.
Where is it? Do I need to do something to enable it?
I’m currently trying to troubleshoot an existing automation that the new update is unhappy with, and it’s a bit of a pain to have to reboot my PI to check things out…
Go to your profile, enable Advanced mode, and you will see it.
I already checked that and it was already enabled. Any other ideas?
Do you have config: in your configuration.yaml?
BTW, you can always restart HA in the services tool.
20190808_21%3A29%3A06_001
Configuration -> Server Control just under General
Do you see the configuration menu on his screenshot?
:flushed: I used to… I disabled that because I thought it may disable the new panel… It works now. Thanks!
I don’t know know why I didn’t think of the services tool… :roll_eyes: Thanks again!
Thanks, but I didn’t even have the configuration menu. Brain fart on my part…
No I don’t, but I also don’t see User or Notifications so it could have been cropped out
I did crop the notifications and user out because it wasn’t relevant. I did leave the lines on the GUI there in hopes that would indicate I hadn’t cropped anything below Developer Tools in that panel.
Sorry for the confusion.
