I am trying to create a Service that will have a field to be filled out that will pass the value to another script. The use case is call a service in an automation that will ask for a temperature Setpoint value then pass that temperature to a script that will load it into a input_number Helper that is used in another service that sets the temperature and retries if thermostat did not update the Setpoint. I have tested the script by loading a value manually in the Helper and it all works fine.
I’m trying to have a single service call in an automation that takes the input for the helper as part of the call…only one call is needed.
This test version I used the normal call to Climate Set Temperature to simplify things. The modified version uses the Helper value to see if the Setpoint was set or not. So I need to store it in the Helper.
Here is what tried but doesn’t work.
Script -
alias: Set Helper and Therm with Retry
sequence:
- service: input_number.set_value
value: {{ value }}
entity_id: input_number.lr_setpoint
- service: climate.set_temperature
temperature: "{{ states('input_number.mbr_setpoint') }}"
entity_id: climate.living_room
mode: single
Service Call -
sequence:
- service: script.Set Temp Modified
value:
entity_id: script.set_helper_and_therm_with_retry
Thanks for any help in advance.
