New sonoff device not discovered in home assistant
Hi complete newbie to the world of home assistant and i apologise already if this has been asked already but can some one show me in simply terms how to do the following.
I have already installed sonoff with Hacs and have a tx light switch already installed and working fine with HA I have purchased another switch for another room, connected it to the we link app ok and it’s working fine but it’s not showing up on HA can some one walk me through the steps to get this showing up on HA so I can control it thanks again for your help
Are the switches the same model?
Make sure you have the latest SonoffLAN (integration) updates also.
Yes the switches are the same model will check for which sonoff integration I have
Just updated the latest sonoff update but new device is still not showing up on devices and services
Do a complete reboot of the unit. I had to do that.
Hi all I saw a article saying some people were having the same issues and someone told them to change a couple things in the config yaml file which I tried and once restarted it was fine with the new device showing up and working ok, thanks for all you help.
Hi ,
Can you share the link for the article please…
Regards
Mark, I am havingthe same problem you had with a new sonoff switch not showing up in HA (other switches are all showing up). Rebooted and still no joy. Could you refer me to the article which you said solved your issues? Thanks.
So for me the solution was that I removed the Sonoff integration, then tried to reinstall and once doing it I did not have any devices. I found out that it now my ewelink requires a password (probably I set one somewhere last year), but HA created the entry nevertheless with the old (passwordless) setting. After realizing that I am using a password now, I re-created the entry, this time adding the password and then my new devices which I was missing did show up, but not my old devices. So I am assuming that some sort of double user started to exist, my passwordless entry owning my old devices and the one with the password owning my new devices, but both had the same user ID so HA could not create both. After this, I factory reseted the old devices, re added them to ewelink and now they exist under the same ID and show up in HA.
Hi, any luck with solving this issue? same problem here.
I had the same problem. If you use 2 username (one in ewelink app and one in HA) you have to share the new device with the account used in HA.
