NEW Sonoff local
Sonoff
A component for working with eWeLink devices on a local network. Devices must be updated to firmware version 3. The LAN must support Multicast.
Component Highlights:
works with original Sonoff firmware, no need to reflash devices
works on a local network, there are no brakes on Chinese servers
you can get a list of devices from eWeLink servers, or configure it manually (the list is saved locally and may no longer be requested)
instantly receive new device status by Multicast (hello Yeelight)
it is possible to change the type of device (for example, light or fan), for convenient integration into voice assistants
It is possible to combine several channels into one light source and control the brightness
In your last update sonoff POW r2 stop working Unknown device_class 1000853db7
9:40 custom_components/sonoff/init.py (ER
Please write to the author on github.
Will the Sonoff RF be implemented in furture updates?
Its already implemented
I found out that my stuff connected via this component becomes unawailable unless I cut the power or turn it on via exelink app. Then again everything works.
Hi…
Need help, I have installed and configure as per Drzzz vid.
The .json file was created but no devices show up.
My rooter does look like it supports multicast
