Hello I’m very new to Home Assistant, so I’m still learning all the things. The first thing I noticed however is the weather card on the overview screen is incorrect. Everything from the temperature, condition, forecast, just everything. Any advice on this would be great.
Did you setup your location during the initial setup?
welcome.
I appreciate you are new, but a screenshot or details would help. Do you mean the information is way out, or a little bit out or there is no info?
As silvrr suggested, could be your location if its just a bit off / working but not accurate
Sorry for being vague. I did set my location on setup, and as far as details everything its displaying is simply just wrong. It’s the wrong weather conditions, the temperature is off by 5-10 degrees, wind speed, humidity, just everything.
