Jeez I think I would have figured this out as this is definitely not the first time I’m using reverse proxies.
Setup
VM (on xcp-ng) running Home Assistant
Ubuntu VM (on freenas) running docker traefik
I’m trying to use traefik as a reverse proxy for Home assistant
Home Assistant (known as -homeassistant.domain.com-) on 10.0.20.10
-ha.domain.com- (reverse proxy) on 10.0.1.95
I’ve obtained SSL cert via LE for the traefik reverse proxy and confirm within traefik dashboard
I can reach http://10.0.20.10:8123 directly and http://homeassistant.domain.com:8123
Traefick Reverse Proxy via the following config:
http:
routers:
ha.domain.com:
rule: "Host(`ha.domain.com`)"
entryPoints:
- web
- websecure
service:
- sv_proxy_pass_ha.domain.com@file
tls:
options: modern@file
certResolver: le
domains:
- main: ha.domain.com
sans:
- ha.domain.com
services:
sv_proxy_pass_ha.domain.com:
loadBalancer:
servers:
- url: http://homeassistant.domain.com:8123
Configuration of homeassistant
I’ve edited /config/configuration.yaml (and totally killed the trusted proxies section – yes I’m aware its redundant but I was desperate).
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
http:
use_x_forwarded_for: true
trusted_proxies:
- 10.0.1.0/24
- 10.0.20.0/24
- 127.0.0.1
- ::1
- 10.0.1.95
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
I’m receiving this error:
2021-09-07 02:42:21 ERROR (MainThread) [homeassistant.components.http.forwarded] A request from a reverse proxy was received from 10.0.1.95, but your HTTP integration is not set-up for reverse proxies
So I don’t get it – why isn’t home assistant setup for reverse proxies? I’m really confused at this point.
