I copied and pasted zigbee2mqtt/# into listen to a topic and pushed start listening.
Nothing on that screen or in the z2m add on logs.
here is a sample of my logs this morning.
zigbee2mqtt:info 2020-01-03 07:45:58: MQTT publish: topic ‘zigbee2mqtt/0x00124b000be8944e’, payload ‘{“state”:true,“led_state”:false,“linkquality”:10,“description”:“64527/0xF0D1B800000E0305”,“type”:“NEIGHBOR”,“rssi”:0}’
zigbee2mqtt:info 2020-01-03 07:46:58: MQTT publish: topic ‘zigbee2mqtt/0x00124b000be8944e’, payload ‘{“state”:true,“led_state”:false,“linkquality”:13,“description”:“64527/0xF0D1B800000E0305”,“type”:“NEIGHBOR”,“rssi”:0}’
zigbee2mqtt:info 2020-01-03 07:46:58: MQTT publish: topic ‘zigbee2mqtt/0x00124b000be8944e’, payload ‘{“state”:true,“led_state”:false,“linkquality”:13,“description”:“0/0x00124B000BE89F7A”,“type”:“COORD”,“rssi”:8}’
All logs look good…z2m addon and mosquitto addon
I have 2 devices in the
\share\zigbee2mqtt\devices.yaml file
But they do not show up as entities when I try to create a card for them
I still see nothing from listening to topic zigbee2mqtt/# but mqtt-explorer running on my PC shows this.
I guess I could try a different broker than Mosquitto
First - Thank You for helping!
Yes I did Create a User
here is my config
“logins”: [
“username”: “!secret mosquitto_user”,
“password”: “!secret mosquitto_password”
“anonymous”: false,
“customize”: {
“active”: true,
“folder”: “mosquitto”
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”,
“require_certificate”: false,
“quiet_logs”: true
have you got it working again (without reinstall the whole thing)?
Ahhh…sorry, I see, it’s from Jan 20…ok, that’s a while.
But I run into a similar story…ikea bulps and remotes are still working, but I can not learn new ones into the system.
Now, I had the great idea to reinstall the Mosquitobroker … super. Now all ikea-integrations are gone and I cannot reinstall them again. urgs. therefor my question to this old thread. Found nothing else what sounds like this problem…
