New user and a question
Hello: Ive just started to play with HA, and so far i like it. running on my pi, controlling some hue lights (5) a couple GE(Link bulbs) a handful of wemo light and wall outlet switches and several SONOS Speakers.
I am unsure if what i see for a certain part is what to expect perhaps someone can point me in he right direction.
I have a wink hub which connects to some lights, and also a Z-Wave door lock and thermostat.
The wink app sees the door lock and thermostat, and they are controllable with the app.
but using wink in the yaml(HA) shows only lamps connected to the hub not the door lock or thermostat.
Is this to be expected?
i was trying to use wink, to eliminate a separate Z-Wave usb, as Ive seen posted as information.
any comments or additional information would be appreciated.
Locks with the wink component should work . If Wink is loaded correctly it should add the Lock when discovered.
Any errors in your logs?
