On the monitor that the pi is connected to, it says
systemd-journald.service: Found left-over process 3150 (systemd-journal) in control group while starting unit. Ignoring.
This usually indicates unclean termination of a previous run, or service implementation deficiencies.
systemd-journald.service: Found left-over process 3154 (systemd-journal) in control group while starting unit. Ignoring.
systemd-journald.service: Start operation timed out. Terminating.
systemd-journald.service: Main process exited, code=killed, systes=15/TERM
systemd-journald.service: State ‘stop-final-sigterm’ timed out. Killing.
The Hassio name is not used anymore. There were 2 ways of installing hassio : download a complete image from the home assistant webpage, as you did. Then you run hassio on hassos, and is now know as ‘Home Assistant’. The other way was called ‘hassio on generic linux install’, where you install hassio on the linux os of your choice. This is now know as ‘Home Assistant Supervised’.
Pinging 192.168.X.XX with 32 bytes of data:
Reply from 192.168.X.XX: bytes=32 time=5ms TTL=64
Reply from 192.168.X.XX: bytes=32 time=8ms TTL=64
Reply from 192.168.X.XX: bytes=32 time=12ms TTL=64
Ping statistics for 192.168.X.XX:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 5ms, Maximum = 12ms, Average = 7ms
Can you try accessing it in incognito mode on your browser, if not have a look here https://www.home-assistant.io/hassio/commandline/ if you haven’t set anything up though you maybr better off, doing a fresh install.
Do you have a backup/snapshot, try accessing the system via SMB \192...*\ make sure you copy the configuration.yaml file if you can in the config directory.
Then we have a problem. You did not install the samba add-on, and are not sure if you installed the ssh add-on. So no way to reach the non-functioning HA installation. There is one thing (not very good, but that is all that is left), cut the power of the Pi and plug it back in.
