I have just setup my rpi3 with Home Assistant having being running OpenHab for the last few years. Most of my devices are sonoff devices flashed with Tasmota
I have installed HA, setup an additional user called mqtt and changed my devices to use the new IP address and username and password… installed the Mosquitto broker and left the configuration as is (as im using a HA user).
the Mosquitto broker logs show the user connecting but no devices show up in intergrations. Ive read forum posts (most seem out of date) and watched a few youtube videos but im no further forward. any help would massively appreciated.
[12:25:05] INFO: Setup mosquitto configuration
[12:25:05] WARNING: SSL not enabled - No valid certs found!
[12:25:05] INFO: No local user available
[12:25:06] INFO: Initialize Hass.io Add-on services
[12:25:06] INFO: Initialize Home Assistant discovery
[12:25:06] INFO: Start Mosquitto daemon
1585139106: mosquitto version 1.6.3 starting
1585139106: Config loaded from /etc/mosquitto.conf. 1585139106: Loading plugin: /usr/share/mosquitto/auth-plug.so
1585139106: |-- *** auth-plug: startup
1585139106: ├── Username/password checking enabled.
1585139106: ├── TLS-PSK checking enabled.
1585139106: └── Extended authentication not enabled. 1585139106: Opening ipv4 listen socket on port 1883.
1585139106: Opening ipv6 listen socket on port 1883. 1585139106: Opening websockets listen socket on port 1884.
1585139106: Warning: Mosquitto should not be run as root/administrator. 1585139108: New connection from 172.30.32.1 on port 1883.
1585139109: Socket error on client <unknown>, disconnecting.
1585139109: New connection from 172.30.32.1 on port 1883. [INFO] found homeassistant on local database
1585139109: New client connected from 172.30.32.1 as auto-A0C6F36D-B0F9-1891-2B37-364655D0D737 (p2, c1, k60, u'homeassistant').
1585139111: New connection from 192.168.1.190 on port 1883. [INFO] found mqtt on Home Assistant
1585139113: New client connected from 192.168.1.190 as SonoffBasic01 (p2, c1, k10, u'mqtt').
1585139113: New connection from 192.168.1.212 on port 1883.
1585139113: New client connected from 192.168.1.212 as rgbswitch02 (p2, c1, k10, u'mqtt').
Thank you so much, I didnt even realise there was settings in dev tools!
as soon as I did this I got
Message 1 received on sonoff/SonoffBasic01/LWT at 1:46 PM:
Online
QoS: 0 - Retain: true
Message 0 received on rgbswitch/rgbswitch02/LWT at 1:46 PM:
Online
however I still got no devices within intergrations
Are those your devices?
Not sure Integration you use but be sure Integration s topic match those above. In my experience if no message received device may not show but I can’t remember exactly
yeah they are two different devices (ive turned the others off while I get these working), ive not changed the config of the devices since using openhab other than the username and password for mqtt
im just using the Mosquitto broker intergation, its difficult to say much more than this as its all brand new to me
I think you only added the MQTT integration?
This will only establish the communication between HA and mqtt server.
You must now add the devices using switch, sensor or other integrations separately like below. If you done that maybe post what you have for the (2) switchesswitch:
OK I now have devices working from the main overview page, I can switch devices on and off and the states are also working (if i switch the device on/off from elsewhere)
all my switches are now showing as entities but not as devices so I am unable to use them in the automation section, I cant find anyway to add them to devices either.
