Okay, I feel I am getting closer to the solution, just not quite there yet…this is what I did so far.
$ sudo systemctl stop [email protected]
$ sudo su -s /bin/bash homeassistant
$ source /srv/homeassistant/bin/activate
$ pip3 install myusps <--- I GET AN ERROR AT THIS POINT, BUT HAVE NO IDEA WHAT IT MEANS
ERROR : " compilation terminated.
Compile failed: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
creating tmp
cc -I/usr/include/libxml2 -c /tmp/xmlXPathInit4k5mo6ty.c -o tmp/xmlXPathInit4k5mo6ty.o
/tmp/xmlXPathInit4k5mo6ty.c:1:26: fatal error: libxml/xpath.h: No such file or directory
#include "libxml/xpath.h"
Could not find function xmlCheckVersion in library libxml2. Is libxml2 installed?
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
Command "/srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-j69i57cc/lxml/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-81qov3v9-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.4/lxml" failed with error code 1 in /tmp/pip-build-j69i57cc/lxml/"
The issue is a missing dependency. You need to make libxml2-dev or libxml2-devel (depending on the operating system you are using) available on your system.
I can confirm this. Do this first:
sudo apt-get install libxml2-dev
sudo apt-get install libxslt1-dev
Then get on homeassistant virual env to install myusps with:
pip3 install myusps
It confirms installed. So I restarted HA, then I got this in the home-assistant.log file:
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/myusps/__init__.py", line 108, in get_profile
profile = _require_elem(session.get(PROFILE_URL), PROFILE_XPATH)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/myusps/__init__.py", line 62, in _require_elem
raise USPSError('Not logged in')
myusps.USPSError: Not logged in
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 151, in _async_setup_platform
entity_platform.add_entities, discovery_info
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/sensor/usps.py", line 48, in setup_platform
add_devices([USPSSensor(session, config.get(CONF_UPDATE_INTERVAL))])
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/sensor/usps.py", line 58, in __init__
self._profile = myusps.get_profile(session)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/myusps/__init__.py", line 100, in wrapped
_login(*args)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/myusps/__init__.py", line 90, in _login
_save_cookies(session.cookies, session.auth.cookie_path)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/myusps/__init__.py", line 41, in _save_cookies
with open(filename, 'wb') as handle:
PermissionError: [Errno 13] Permission denied: './usps_cookies.pickle'
@happyleaves, no worries. Thank you for even coming up with such a cool idea! Could you, please write the exact steps of how it should be installed for it to work on the Pi image or point me in the right direction?
@tchellomello The link you have attached does not work. Could you please double check it? I get a “404: Not Found” error.
Thanks for your contributions to HA. I love the system.
I installed 36.1 just now to use newest version of USPS. I now get this error:
17-01-17 08:01:34 homeassistant.components.sensor: Error while setting up platform usps
File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_component.py", line 151, in _async_setup_platform
File "/usr/lib/python3.5/asyncio/futures.py", line 379, in __iter__
File "/usr/lib/python3.5/asyncio/tasks.py", line 297, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 292, in result
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/sensor/usps.py", line 51, in setup_platform
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/sensor/usps.py", line 65, in __init__
self.update()
File "/usr/local/lib/python3.5/dist-packages/homeassistant/util/__init__.py", line 296, in wrapper
result = method(*args, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/sensor/usps.py", line 81, in _update
for package in myusps.get_packages(self._session):
File "/home/jeff/.homeassistant/deps/myusps/__init__.py", line 98, in wrapped
return function(*args)
File "/home/jeff/.homeassistant/deps/myusps/__init__.py", line 118, in get_packages
dashboard = _require_elem(session.get(DASHBOARD_URL), DASHBOARD_XPATH)
File "/home/jeff/.homeassistant/deps/myusps/__init__.py", line 65, in _require_elem
raise ValueError('No element found')
ValueError: No element found
I am receiving the same error as Jaalperin. After reading your comment, I went into my USPS account and found where you actually Opt-In to the My USPS service (something we might want to make more clear on the component page). I am still getting the same error, however I do not have any pending packages at this time. I assume we should wait until we have a package listed under the “My Packages” section before setting the sensor up?
I just made a quick edit to the USPS component page that says you need to Opt-In to the service and submitted the pull request. First time doing this, so I hope I did it right.
I returned to usps.com and discovered that I was not opted-in. Sorry, thought I was. Anyway, now I am, but I get this error:
17-01-17 12:42:37 homeassistant.components.sensor: Error while setting up platform usps
future.result()
self.update()
As noted above, this is likely because you don’t yet have any packages listed. It’s a bug in the component’s module dependency (when I wrote it, I already had packages listed and couldn’t test the no-package state – oops).
So once a package shows up, it should start working.
I’ve installed the dependencies and did the pip3 reinstall. But I am still having a problem.How do I troubleshoot this issue ?
Jan 17 19:13:48 ha hass[23454]: INFO:homeassistant.loader:Loaded sensor.usps from homeassistant.components.sensor.usps
Jan 17 19:13:49 ha hass[23454]: INFO:homeassistant.bootstrap:Setting up sensor
Jan 17 19:13:49 ha hass[23454]: INFO:homeassistant.components.sensor:Setting up sensor.usps
Jan 17 19:13:58 ha hass[23454]: ERROR:homeassistant.components.sensor:Error while setting up platform usps
Jan 17 19:13:58 ha hass[23454]: Traceback (most recent call last):
Jan 17 19:13:58 ha hass[23454]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 151, in _async_setup_platform
Jan 17 19:13:58 ha hass[23454]: entity_platform.add_entities, discovery_info
Jan 17 19:13:58 ha hass[23454]: File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
Jan 17 19:13:58 ha hass[23454]: yield self # This tells Task to wait for completion.
Jan 17 19:13:58 ha hass[23454]: File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
Jan 17 19:13:58 ha hass[23454]: value = future.result()
Jan 17 19:13:58 ha hass[23454]: File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
Jan 17 19:13:58 ha hass[23454]: raise self._exception
Jan 17 19:13:58 ha hass[23454]: File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
Jan 17 19:13:58 ha hass[23454]: result = self.fn(*self.args, **self.kwargs)
Jan 17 19:13:58 ha hass[23454]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/sensor/usps.py", line 51, in setup_platform
Jan 17 19:13:58 ha hass[23454]: add_devices([USPSSensor(session, config.get(CONF_UPDATE_INTERVAL))])
Jan 17 19:13:58 ha hass[23454]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/sensor/usps.py", line 65, in __init__
Jan 17 19:13:58 ha hass[23454]: self.update()
Jan 17 19:13:58 ha hass[23454]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/util/__init__.py", line 296, in wrapper
Jan 17 19:13:58 ha hass[23454]: result = method(*args, **kwargs)
Jan 17 19:13:58 ha hass[23454]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/sensor/usps.py", line 81, in _update
Jan 17 19:13:58 ha hass[23454]: for package in myusps.get_packages(self._session):
Jan 17 19:13:58 ha hass[23454]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/myusps/__init__.py", line 98, in wrapped
Jan 17 19:13:58 ha hass[23454]: return function(*args)
Jan 17 19:13:58 ha hass[23454]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/myusps/__init__.py", line 127, in get_packages
Jan 17 19:13:58 ha hass[23454]: 'shipped_from': row.xpath(SHIPPED_FROM_XPATH)[1].text.strip()
Jan 17 19:13:58 ha hass[23454]: AttributeError: 'NoneType' object has no attribute 'strip'
